Grand Cherokee to 72 RR Rear Disc Brake Swap Possible?
#32903
12/25/06 08:42 PM
12/25/06 08:42 PM
Posts: 1,230 Pittsburgh, PA
wayfarer1
Pittsburgh, PA
Has anyone tried or is it even possible to swap the rear disc brakes from a 94 or newer Grand Cherokee or Durango to the 8 3/4 rear in my 72 RR. What is involved in the swap, will it work and will I have any problems eliminating the electronics for the rear discs?
I am planning on doing a 11.75 front disc swap and keeping my power setup.
Any help would be appreciated!
Current Project: 72 Roadrunner 340/727/Petty Blue/White Roof Strobe Stripe/Black Bucket Interior
71 Demon project
Re: Grand Cherokee to 72 RR Rear Disc Brake Swap Possib
[Re: wayfarer1]
#32904
12/25/06 10:22 PM
12/25/06 10:22 PM
yea, it'll work but you have to watch the outside dia. for wheel size.
[Re: wayfarer1]
#32906
12/25/06 10:50 PM
12/25/06 10:50 PM
most have 16" wheels, for brake clearance. look around some jeeps have 15's then order them for that year.
#32907
12/26/06 01:44 AM
12/26/06 01:44 AM
My Jeep Cherokee 6 cyl.is a 98 with 4 wheel discs,it has factory 15" rims.
Re: Grand Cherokee to 72 RR Rear Disc Brake Swap Possible?
[Re: wayfarer1]
#32908
12/26/06 10:40 AM
12/26/06 10:40 AM
Posts: 8,144 Arkansas
340727dart
Arkansas
About three months ago, I swapped '95 Grand Cherokee rear discs onto my Dart's 8 1/4. It was a fairly straight forward conversion with little trouble. You will need to take a Dremel and remove a few thousandths from the inside diameter of the caliper mounting bracket in order to get it to fit over your axle housing. It took me about five minutes per side. You'll need longer bolts to mount the bracket to the axle housing. The one drawback is that you won't be able to utilize the internal parking brake. The spacing of the axle flange puts the rotor too close to the backing plate. I drilled out the rivets and removed the backing plate. However, if the parking brake is a big deal, you might want to consider a 1/4" spacer on the face of the axle flange. A 1/8" spacer might do the trick.
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
[Re: 340727dart]
#32909
12/26/06 11:35 AM
12/26/06 11:35 AM
wayfarer1
Pittsburgh, PA
Thanks guys for all the help, now I just need it to warm up a little and stop raining so I can hit the junkyard to round up the parts. I plan on having the housing and all the rear brake and some other parts powder coated in January.
Thanks, Joe
71 Demon project
[Re: 340727dart]
#32911
01/25/07 02:48 AM
01/25/07 02:48 AM
Anyone have any pictures of this type of swap? I would like to see... I planned on ditching my power booster & old style master cylinder for the new style manual master cylinder. Would this setup (new style manual master cylinder with front & rear disc) work with the cherokee rear disc conversion & stock power disc calipers up front?
