ECU wiring tech article question #32684
12/11/06 02:07 PM
12/11/06 02:07 PM
Anonymous OP
Anonymous OP
In the Moparts Tech Archive titled "Awesome ECU wire diagram" the diagram shows a 2 prong resistor. The new resistor I got from the parts store for my '73 440 with electronic ignition has 4 prongs. The maintenande manual I have shows the 4 prong to be correct aas well. Can you tell me how the wiring diagram would change for the 4 prong resistor or should I use a two prong resistor or can I use only two of the 4 prongs, if so, which ones? Any help you can give me so as not to burn up the ECU.
Thanks!
Brcue
Re: ECU wiring tech article question #32685
12/11/06 02:35 PM
12/11/06 02:35 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
The early mopar ecu's had 5 pins in the connector the mopar performance and late ecu's have 4 pins. If you have all the wiring for the ballast with 4 terminals it will work just fine with either ecu. The extra resistive elment in the ballast and the extra wire in the connector to the ecu is just not used.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: ECU wiring tech article question [Re: dgc333] #32686
12/11/06 03:14 PM
12/11/06 03:14 PM
Anonymous OP
Anonymous OP
Dave,
I don't have any wiring I'm starting the wiring from scratch. The tech article shows the wiring using a 2 prong resistor. How would it change with a 4 prong resistor? Other options?
Bruce
Re: ECU wiring tech article question #32687
12/11/06 04:02 PM
12/11/06 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's the 5-pin schematic:
