B Body Dana 60, Pinion Snubber, Driveline Vibration
#326644
05/23/09 09:43 PM
05/23/09 09:43 PM
Posts: 757 Northern VA
bulletpruf
Northern VA
Fellas -
My 68 RR (hemi, 727, Dana 60) has some driveline vibration at about 60+ mph. Wasn't happening until recently.
Lubed the u joints (I need to swap to solid u joints) today, checked u bolts for tightness. Got pulled over on the test drive (he liked the car, no ticket), but still vibrating.
Car does not have a pinion snubber. When I got underneath, I saw where it looks like the very rear of the driveshaft smacked the floorpan - must have been an extreme angle. My guess is that I tweaked the rear u joint when this happened.
My plan - drop the driveshaft, get solid Spicer u joints installed. Install a pinion snubber. Driveshaft stuff I can handle, but any ideas on a good pinion snubber? Doesn't have to be 100% correct Mopar; car is slightly modified, and it's not going to be concourse judged.
Thanks,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration
[Re: bulletpruf]
#326645
05/24/09 01:21 PM
05/24/09 01:21 PM
bulletpruf
Northern VA
Driveshaft is out and will go to the shop Monday or Tuesday.
Any recommendations on pinion snubbers?
Thanks,
Scott
[Re: bulletpruf]
#326646
05/24/09 09:28 PM
05/24/09 09:28 PM
bulletpruf
Northern VA
Feel like I'm having a one-sided conversation here, but I bought a Mopar adjustable pinion snubber from Jeg's...
[Re: bulletpruf]
#326647
05/24/09 11:02 PM
05/24/09 11:02 PM
Posts: 546 Stuart FL
mercman1
Stuart FL
What rpm is the engine turning when the vibration starts and can you drive through it? Say it starts at 3500 and vibrates til 4800??? will it vibrate in neutral at the same rpm???
[Re: mercman1]
#326648
05/25/09 12:07 AM
05/25/09 12:07 AM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
I don't like pinion snubbers. They hinder suspension travel. If the universal joint is going that high from axle wrap it's the fault of weak leaf springs.
Is the vibration speed or rpm related?
I correct my statement. I don't like adjustable pinion snubbers. The factory one will not hinder travel.
[Re: bulletpruf]
#326655
05/27/09 01:43 PM
05/27/09 01:43 PM
bulletpruf
Northern VA
Driveshaft shop says the front u joint is bad. They'll replace it with a solid joint, straighten, and balance it. Should be back in the car this evening. Maybe I can take a test drive without getting pulled over this time...
Thanks,
Scott
[Re: bulletpruf]
#326656
05/27/09 01:50 PM
05/27/09 01:50 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Cool keep us posted....subscribing
1MYTGTX
[Re: bulletpruf]
#326657
05/28/09 06:58 AM
05/28/09 06:58 AM
bulletpruf
Northern VA
#@)(&$)#@Q*I$~!!!
Driveshaft went back in last night, freshly balanced, straightened, painted, new u joints front and rear. Took her for a drive and the vibration is still there. I only felt it as I was going pretty fast (maybe 60-80 mph?). Goes away when I put it in neutral. Does not appear to be rpm related; don't feel it at high rpms at lower speeds.
This is getting frustrating...
Any other thoughts? I'll check the trans bolts for tightness this weekend.
Thanks,
Scott
[Re: bulletpruf]
#326661
05/28/09 11:22 AM
05/28/09 11:22 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
Thanks,
Scott
Why would the front joint have gone bad if the rear was what hit the floor?
Also STRAIGHTEN ??? , straighten WHAT ???
[Re: JohnRR]
#326663
05/28/09 04:45 PM
05/28/09 04:45 PM
bulletpruf
Northern VA
Thanks,
Scott
Driveshaft shop said that the front joint was old, and it was bad. Probably the result of age, not rear diff rotation. Surprised that they didn't replace the joint when they built the car.
The shaft wasn't bent, but they check for straightness (and straighten it, if it's bent, I guess) when they balance it.
Thanks,
Scott
