Indeed, the tracks and the seats started life as separate entities before they were assembled. Technically, the same can be said for ALL of the pieces under your seat (lower/upper seat track halves, etc.). Some of those components can still be separated with ease, others have been tacked or otherwise made more challenging to separate as part of the manufacturing process.
You have already been advised as to the recommended and by far easiest method of removing the front seat from your car. Once you follow that path, knock yourself out with taking other stuff apart. Ignoring that advice is only going to make your job needlessly difficult.
