Ok so I finally got back to work on the race truck
I was going to make it raised up gasser style but seeing that I already have all the must II stuff i am going to build it on the ground and I will build the 37 willys sedan as a nose up gasser....
so today I cut off the stock toyota frontend stuff and got the Mustang II frontend in place and made most of the plates to mount it( I still need to finish it lower ones and finish grinding the upper plates smooth.
I still need to cut some more of the toyota frame rails off to blend into the 2x2 that will mount the front of the nose. Ron...
I hope to get much more work done and keep this thread going again.....
here is the stock toyota stuff:
here is the Mustang II frontend mounted:
here is the area that still needs to be trimmed off:
here is a overall shot:
