Re: progress on the race truck project
[Re: RodStRace]
#32352
01/17/07 02:26 PM
01/17/07 02:26 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Are you going to weld in the seat brace and belt mounts before you paint? LOOKS GREAT!!!
I wish I could but I don't have the seats yet so I want to paint the cage while its easy to get at. then I will have to weld the window net,seats and belt mounts later and touch up the paint on those areas also some of the cage will have padding, so I am not sure how much of the cage will show anyways Ron...
[Re: bohmer2]
#32355
01/19/07 05:37 PM
01/19/07 05:37 PM
Mopar Ron
thanks Brian, I thought about making the door 3" longer but decieded to add 3" to the cab just behind the door area from the botton to the top and move the back of the cab back the 3" there. with the chop the cab needed to be split and a filler piece made to fill that area, after the top was set back on we found that we need to make a 1 3/4" filler piece, but when you add in the 3" that i moved the cab back the filler piece needs to be 4 3/4" I will make the filler piece 2" wider than the opening and overlap it across the roof. that way I can weld it inside and outside Ron...
[Re: Mopar Ron]
#32356
01/19/07 06:44 PM
01/19/07 06:44 PM
Mopar Ron
here are a few more pics from today, I am letting the paint dry on the rear bars, i have the back of the cab welded back on and the front top fitted, and the rear top section has been fitted and cut out for the rear bars, also the rear bars are finally welded in Ron.. where I added to the cab: rear bars welded in and painted:
[Re: Mopar Ron]
#32357
01/20/07 09:13 AM
01/20/07 09:13 AM
Posts: 82 Maryland
33Plymouth
Maryland
Hi Ron, Once again I am simply amazed at your craftsmanship and would like to thank you for allowing us to watch the progress. How will you finish the cab where the rear bars come out? Also in one of the pictures I see your brother's sedan, if I remember correctly you are going to paint that for him, what color? Hughey
[Re: 33Plymouth]
#32358
01/22/07 09:59 PM
01/22/07 09:59 PM
Mopar Ron
sorry I didn't get back to this post sooner I am thinking about making a little cover for where the Rear bars come through the cab(see pics below) we plan to paint my brothers car candy brandywine with darker fenders, the body will be painted over burgandy base and the fenders will be painted over black base.
here are the latest pics of the finished rollcage and the chop top. got the back window area welded back in too, I only chopped the back window 1 1/2" instead of 3 1/2" like the body. you can see the pieces that I made to fill in the top area and the patches that needed to be made. I still have a few more patches to do and a bunch more spotwelds. Ron..
[Re: moparx]
#32361
01/25/07 10:16 PM
01/25/07 10:16 PM
Mopar Ron
lookin good ron ! are the rear down tubes of the cage welded to the rear cab tin ? what are your plans for the firewall ?
Yes the cab is now welded to the cage, I started to make cab to cage mounts and everything started to get very solid so i went ahead and welded the rear bars too., I plan to make some nice covers to weld over that area. Not sure yet how the firewall will be. I'm thinking about a slight curved one. Ron...
[Re: JonsGottaDusta]
#32369
02/03/07 01:09 AM
02/03/07 01:09 AM
Lookin' good there Mr.
[Re: Mopar Ron]
#32370
02/03/07 03:32 PM
02/03/07 03:32 PM
Posts: 228 Kentucky
Flipper1938
Kentucky
Roll that thing out in the driveway so we can get a good look.
I am curious to see how natural the stretch looks.
