Re: progress on the race truck project
[Re: Mopar Ron]
#32314
12/27/06 10:15 AM
12/27/06 10:15 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
yes the cab is welded to the frame, because I need to run the rollbar through the back of the cab to the rear frame rails so the cab will never come off so I figured might as well make it solid . personally, I would make body mounts with some rubber mounts and make it possiable to remove the body to make it easier to paint the bottom and the chassis. now that being said, how often does a body really get takin off a frame Ron...
Wow Ron!!! You are making some serious progress on this truck. It seems you know exactly what you want and how to get it there! I left the body on my Allstate removeable for easier painting, but that does complicate things and slow the progress. Great Job!
Mark
[Re: Mopar Ron]
#32321
12/30/06 11:04 AM
12/30/06 11:04 AM
Hemi Allstate
Mt. Eden Ky.
Great job! Will you be using a steel or fiberglass hood? An inspiring amount of work done. Mark
[Re: Hemi Allstate]
#32322
12/30/06 12:08 PM
12/30/06 12:08 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Mark
Thanks guys
Mark, I have to make the hood from the dodge hood and nose cone fit the willys center section, because the body lines are oppisite from the dodge to the willys, the body goes in after the body line on the willys and it comes outward after the body line on the dodge. so mating the dodge stuff to the willys is the best way to go Ron...
[Re: Mopar Ron]
#32323
12/30/06 12:25 PM
12/30/06 12:25 PM
i think this truck build would be a great article in any rod magazine. have you seen the PHR post?
[Re: smokinwoody]
#32325
12/30/06 02:21 PM
12/30/06 02:21 PM
Posts: 6,236 san diego
JonsGottaDusta
san diego
awesome work Ron...I take it you are retired...
nope
[Re: Mopar Ron]
#32331
01/11/07 09:48 PM
01/11/07 09:48 PM
Mopar Ron
well I finally got the tube bender back to my house and picked up the rollbar tubing and started the rollcage here are a few progress pics of what I got done this week. Ron... here is the first fitting of the main bar: this picture is what the front bars will look like: here is the main bar and the back bar in place: fitted back into the cab: here is where I cut the cab to move it back 3": from the pass side with the bar tacked in place: I decieded to put in a rear brace bar: back bars setting in place: lower rear bars mount area, right to the shock mounts: upper area, I have to wait to weld these bars in till I get the back of the cab done and make the front bars, then finish all the welds and finish the chop top: and here is a pic of the filler piece for the added 3" to the cab:
