Re: E body AC Water Valve [Re: 2fast4yourBrain] #322641
05/29/09 09:57 PM
05/29/09 09:57 PM
cataclysm80 Offline OP
First you'd have to figure out what the correct bolts look like. They might be big screws instead of bolts, I'm not sure. I hear they varied through the years, so it may depend on what year you're working on. In another thread it was suggested that the voltage regulator anchor head type may be correct for 70, and that they should be plated the same as the bracket. I don't have any originals myself, but maybe if you post what year/make/model your working on, someone else will chime in?
Tav
Re: E body AC Water Valve [Re: cataclysm80] #322642
05/30/09 01:43 PM
05/30/09 01:43 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
I have the correct bolts for 70 cars and for 71 cars. The head markings are different for each year. The 70 ones have no marking and the 71 ones have an "R" in the center and several circles around the "R". I am out of town on my to a couple of car shows, so I can't post any pictures of them for about a week. Hopefully someone else has the same bolts, if not I will post when I am back. They are bolts, and not screws!
Re: E body AC Water Valve [Re: m46rat] #322643
05/30/09 05:47 PM
05/30/09 05:47 PM
Do they use nuts on the back, or screw into the sheetmetal like the starter relay fasteners?
Tav
Re: E body AC Water Valve [Re: cataclysm80] #322644
05/31/09 12:41 AM
05/31/09 12:41 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
They screw into the sheetmetal
Re: E body AC Water Valve [Re: cataclysm80] #322645
05/31/09 03:19 PM
05/31/09 03:19 PM
None
71rm23 Offline
71rm23  Offline
None
Here's a pic of the water valve installed on the bracket on another car.
Tav
Is anyone repoping or have that valve?
Re: E body AC Water Valve [Re: m46rat] #322646
05/31/09 04:56 PM
05/31/09 04:56 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Tag info for above car:
M26 M31 M42 M44 N41 CTD
H51 J25 L25 L31 M21
B51 C16 C55 G11 G31 G33
V1X U A01 A04 A46 A62
GY3 H6Y3 000 903 0229--
E65 D32 JH23 N1B 1274--
EN2
N85 R11 R31 V5X 26
JH23 N1B 1274--
Tav: It is a non N95 car. What measurements do you need, if any? I bought it as a shell, no A/C, motor or trans. etc.
Your fender tag codes are weird.
Never seen M26 or M44 on a car before. You car didn't come w/chrome exhaust tips?
Re: E body AC Water Valve [Re: 71rm23] #322647
05/31/09 10:58 PM
05/31/09 10:58 PM
used or NOS only. You might try Classic Auto Air, I think they usually have some NOS ones up on Ebay.
Tav
Re: E body AC Water Valve [Re: 2fast4yourBrain] #322648
05/31/09 11:01 PM
05/31/09 11:01 PM
I think they're alright. M26 & M44 would be part of the A46 molding package which is listed on the tag. The tag has CTD which means "continued". There is a second tag, and the first code on it is probably N42 for chrome tips.
Tav
Re: E body AC Water Valve [Re: cataclysm80] #322649
05/31/09 11:20 PM
05/31/09 11:20 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Actually, there shouldn't be an N42 code. [As noted on the second data plate.]
This is a JH car. Dual exhaust came with the N code 383-4. It would have had the turn down exhaust tips. However, N42 could have been optioned.
Only the R/T models (JS) came with the N42 exhaust tips as standard equipment.
This picture is of an E65 N coded 383-4 with only the N41 on the Data Plate
Re: E body AC Water Valve [Re: cudaized] #322650
06/01/09 09:53 AM
06/01/09 09:53 AM
Oops, you're right Ola, guess I was tired last night. I totally overlooked that the second tag info was even there.
Tav
