Re: Whats the best cruising gear?
[Re: ireland383]
#320915
11/24/09 11:40 AM
11/24/09 11:40 AM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
3.55's here, I think you get the best of both worlds with this gear.
Best all around gear if you drive it often.
[Re: Reggie]
#320916
11/24/09 12:02 PM
11/24/09 12:02 PM
Posts: 2,782 USA
JoesMopar
USA
I'm running a 3.55 in my '69 Charger with a 440, 727, 3000-3200 stall, and 295/50/15 BFG's.
@ 70 mph it's around 3200 rpm, on the back roads which are 45 mph zones it's under 2500 rpm.
I don't mind driving it on the interstate, but it does get annoying. Farthest trip I've taken was about 35 miles (70miles RT) and that's enough for me.
But the way I see it, it's not a daily driver for me anyway, just a fun car. I don't have to drive it 100 miles one way and as little cruising as I do in town, the 3.55's are suffcient.
I have an '89 Diplomat AHB that has 2.94's and it is much more relaxing to drive it on the interstate. Around town though the car really isn't the dog you think it would be, but, it has the A999 in it which I think may have a lower first gear.
If I did build another car to do it all with, I would consider the 518 swap if I had an automatic, or saving up and spending the dough for the Keisler if I had a manual.
[Re: patrick]
#320917
11/24/09 07:19 PM
11/24/09 07:19 PM
29 inch tiers and a comp cam extreme energy 230/477
#320918
11/25/09 03:47 PM
11/25/09 03:47 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
I'm on 3.55 with 255/60R15. I had 3.23 on same wheels. Got plenty happy and variation is not that BIGGER to get worried.
Both of them works for cruise, then mileage is what you will need to think. Myself I don't care the 10% mileage change ( Ok I pay US$ 3 to fill my tank on a 74 Charger, so who cares milage LOL ). I mean 10% cause that's more less the gear variation.
overall, 3.23 is the best gear setup for highway to win torque from 2s gears. For street, both works great really. If you are going down from 4s, I think 3.55 is the best to keep some of the high gears you had and FEELS you are not loosing a lot.
[Re: DennisH ]
#320921
11/25/09 07:45 PM
11/25/09 07:45 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
I'm running a 28" tall tire with 4.10 gears behind an A500 overdrive trans. Runs a tick under 2500 RPM at 70. OD was one of the best modifications I made to my car.
[Re: stumpy]
#320927
11/26/09 11:54 AM
11/26/09 11:54 AM
Posts: 2,914 Calgary, Alberta Canada
a12rag
Well . . it certainly all depends what you use your car for . . . in my 74 Duster360 (stock), before going to Carlisle years ago, I swapped out the 8.25" rear end (complete) that had 3.55:1 gears, for another that was 2.45:1 gears !!! Yes, that high . . . with the 360, 727auto, 235/60/14 tires, cruising 70mph = 2500rpm ! With the torquey 360, it has no problem spinning the right rear (yeah a one legger), and love the passing power on the highway !!! Not to mention getting 22mpg @ 70mph !!!! As I have always said, you have to build the car for you . . .for what you want to do. I like driving LONG distances to car shows, not being a drag racer or street fighter. So the car works for me !! Course I miss my big ole C Body for long distance cruising . . . . Just my Cheer Mark A12rag
[Re: DennisH ]
#320930
11/26/09 02:37 PM
11/26/09 02:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Keisler TKO / 354 DANA.
Nice combo.
.......My Daytona runs a Keisler TKO 600 5spd, .64 OD....27" tire 275/60/15,..4:10 Dana.....awesome on the streets with 4:10's...or crusing on the highway in 5th at 80MPH@ 2200-2400 RPM,...with a top speed of 140-150 MPH @ 5700 RPM....your best investment is an overdrive transmission rather than a compromise in gearing
