Page 5 of 5 1 2 3 4 5
Re: modern alternator swaps for BB, highest amp at idle [Re: jeepers007] #32104
12/01/06 07:48 PM
12/01/06 07:48 PM
N.Y.
V
VZCharger Offline
VZCharger  Offline
V
N.Y.
I used the arm from a GM product when I mounted mine, figure if it was a GM alternator then a GM bracket should work . It had a large curve to it that wrapped around the alternator so I didn't need an extension. I just went to the local speed shop and looked through their catalogs 'till I found one that looked like it could work.
70 Charger blown injected BB 07 Charger Daytona Plum Crazy #389 69 Coronet ragtop 96 Ram "Garlits Edition" 88 Conquest TSi
Re: modern alternator swaps for BB, highest amp at idle [Re: jeepers007] #32105
12/01/06 08:57 PM
12/01/06 08:57 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Maybe one of our resident metal workers could fab up a new arm that takes care of this issue. Should be cheap to do... Doesn't need to be anything fancy.
This thread needs to be saved in the tech section!
Re: modern alternator swaps for BB, highest amp at idle [Re: whiplash] #32106
12/01/06 09:14 PM
12/01/06 09:14 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Re: modern alternator swaps for BB, highest amp at idle [Re: Pool Fixer] #32107
12/02/06 03:47 AM
12/02/06 03:47 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Whiplash,
Now that you have the alt. mounted, running, etc., do you think the 144 would clear everything?
Just wondering.
Re: modern alternator swaps for BB, highest amp at idle [Re: Von] #32108
12/02/06 09:26 AM
12/02/06 09:26 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
I think the 144 housing would fit. The issue would be with the bottom bracket, maybe not on a 440, but a new bracket or a different on would be needed for the 383. Why do you need a 140a alternator anyway?
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: modern alternator swaps for BB, highest amp at idle [Re: whiplash] #32109
12/02/06 01:02 PM
12/02/06 01:02 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I know the problem would still exist with the bottom bracket, just wondering about the case.
Do you have any way to see how many amps you are getting at idle?
Do you have your headlights on relays or not?
Just wondering.
