Page 3 of 5 1 2 3 4 5
Re: modern alternator swaps for BB, highest amp at idle? [Re: 70blackfish] #32064
11/22/06 12:18 PM
11/22/06 12:18 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
mine looks like it the same as blown71x but chrome,
its 140 amp 1 wire,
it cost 275.00 at valley alt. in canoga park ca.
they had to build it,
14 volts at idle with my both my fans on and fuel pump and msd.
Re: modern alternator swaps for BB, highest amp at idle? [Re: Verga] #32065
11/22/06 12:23 PM
11/22/06 12:23 PM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
c'mon, guys, I'm trying to get somewhere here, just the facts...
I went to pep boys, found an alt for a 95 impala, cs130, with a serpentine pulley, the bolt holes are 12/6 o'clock (180°, opposed) that looks like it will fit.
The stock alternator has a bolt to bolt distance around 6.5", this one is 7.25". The spacer I should need up top is 3", as stated above. I should be able to rotate the bottom braket down a little and still have some adjustment for tightening...
Now, I need to find a connector for it, the connector on the alt is square, 1 larger connector and 3 smaller ones
blown, is this plug similar to what you have? where did you get the connector? thanks again.
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32066
11/22/06 12:38 PM
11/22/06 12:38 PM
Middle of the US
V
Verga Offline
Verga  Offline
V
Middle of the US
Me too. I need the info also.
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32067
11/22/06 12:45 PM
11/22/06 12:45 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
you wont find my alt. at pep boys.
I gave you the name and city of the place that has them,
tell them you want a 1 wire gm alt for a jenson car
Re: modern alternator swaps for BB, highest amp at idle? [Re: 70blackfish] #32068
11/22/06 12:49 PM
11/22/06 12:49 PM
Middle of the US
V
Verga Offline
Verga  Offline
V
Middle of the US
its 140 amp 1 wire,
I realize Im borderline hijacking this post, but Im gonna give them a call. In case anybody else need the number here it is (818) 882-7511.
Re: modern alternator swaps for BB, highest amp at idle? [Re: 70blackfish] #32069
11/22/06 12:50 PM
11/22/06 12:50 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the connector your looking for can usually be found in the help section as a repair part. there are millions of the cs alternators running around. if the pepboys your going to doesn't have it then go to an autozone.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32070
11/22/06 02:00 PM
11/22/06 02:00 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
Blown,
That's the kind of alternator I was looking for, now I just need to find the application with a 6 rib pulley, I don't mind running the stock 6 rib while I shake things down..
How did you wire it up?
thanks again.
Cadillac went to the serpentine belt in 91 on the RWD fleetwoods with the 5.0. That mite be what your looking for. ac-delco pn 321-1068 100amp
Re: modern alternator swaps for BB, highest amp at idle? [Re: JeffC] #32071
11/22/06 02:16 PM
11/22/06 02:16 PM
Cornfield. IN
Clair Offline
Pot Stirrer #4
Clair  Offline
Pot Stirrer #4
Cornfield. IN
I don’t remember right off hand why the Chrysler alt will never match the output of a GM style at idle but it has to do with the design of the system.
We covered that 20 years ago in class.
Re: modern alternator swaps for BB, highest amp at idle? [Re: Clair] #32072
11/22/06 02:18 PM
11/22/06 02:18 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
As mentioned above, The pigtails are available at any of the dime store auto parts places.
Rick
Re: modern alternator swaps for BB, highest amp at idle? [Re: Blown71X] #32073
11/22/06 03:32 PM
11/22/06 03:32 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
if you have a 1 wire you dont need a pigtail
Re: modern alternator swaps for BB, highest amp at idle? [Re: 70blackfish] #32074
11/22/06 05:07 PM
11/22/06 05:07 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
True...BUT..as was posted, He is wanting something that is easily available in most auto parts stores in case something dies, One wire`s are not.
With this extremely simple wiring setup an "off the shelf" unit can be used without fear of having to find a one wire....which personally I don`t care for anyway.
Rick
Re: modern alternator swaps for BB, highest amp at idle? [Re: Blown71X] #32075
11/22/06 10:05 PM
11/22/06 10:05 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i looked at advanced autos web site, and for 89 caddy i didnt see a 5.0, but it looks like any other GM CS series alt, an according to them is a 120 amp, and the price starts at about 95 bucks online, can the cs series be clocked??
Re: modern alternator swaps for BB, highest amp at idle? [Re: Dakota_Don] #32076
11/22/06 10:42 PM
11/22/06 10:42 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Look again
1989 caddy Fleetwood brougham 5.0
Advance part number:P79223
Re: modern alternator swaps for BB, highest amp at idle? [Re: Blown71X] #32077
11/22/06 11:44 PM
11/22/06 11:44 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
k ill look, looked at all but that one, but i assume they use the same alt
Re: modern alternator swaps for BB, highest amp at idle? [Re: Blown71X] #32078
11/24/06 10:55 AM
11/24/06 10:55 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
I googled that part number, here's some more stock applications to ask for, and a link to a checy site that also shows the retrofit for older chvy's:
Link>>>> http://home.centurytel.net/rshannon/cs130.htm
Are there any size differences between the CS130 and the CS144?
CS series wiring pin-out:
S = Heavy gauge wire to the battery supply (loop to output post on rear of alternator).
F = not used.
L = Small gauge wire that comes from the idiot light and energizes the alternator.
P = not used.
AC Delco sells a SI-to-CS adapter pigtail or you'll need to purchase a new end for the CS alternator. I got mine from the local salvage yard for $2.50. If you go the conversion pigtail route, be aware that there are TWO TYPES, a non-resistor model for use WITH the idiot light, and a resistor model for use WITHOUT the idiot light.
Non-resistor adapters: use WITH idiot light
- AC Delco: 8077
- Haywire: 2110
- Painless Wiring: 30707
Resistor adapters: use WITHOUT idiot light
- AC Delco: 8078
105 AMP CS130
Get a 105 amp alternator for a 1989 Pontiac Safari Wagon 5.0L. This saves you the trouble of having to swap pulleys as the Safari came with a v-groove pulley, not the serpentine. From Advance Auto Parts the part # is Premium P79223. $78 with a $35 core charge.
Other options are:
(1988-90) Buick Estate Wagon 5.0L
(1988-90) Cadillac Fleetwood Brougham (RWD) 5.0L
(1988-90) Chevrolet Caprice 5.0L
(1988-90) Oldsmobile Custom Cruiser 5.0L
(1988-89) Pontiac Safari Wagon 5.0L
Replaces:
Delco 1101229, 1101275, 1101292
140 AMP CS144
If you want a bad boy 140 amp CS144 Series, they're used on:
(1994-96) Buick Roadmaster 5.7L
(1993-96) Cadillac Fleetwood Brougham (RWD) 5.7L
(1993-96) Chevrolet Caprice 4.3L, 5.7L
(1995-96) Chevrolet Impala 5.7L
(1992-95) Chevrolet Lumina APV Van 3.8L
(1992-95) Oldsmobile Silhouette 3.8L
(1992-95) Pontiac Trans Sport 3.8L
Replaces:
Delco 10479891, 10480201
You'll have to swap pulleys on this model as they came with a six-groove serpentine set-up.
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32079
11/24/06 11:16 AM
11/24/06 11:16 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
more info:
pdf file withthe list of delco part number, amp ratings, series, and clocking:
http://www.acdelcotechconnect.com/pdf/tas_alt_clock_cs.pdf
More pictures and info on the CS series:
http://oljeep.com/gw/alt/Alternator_Theory.html#Section_3
this is good stuff, I'm thinking about going with the cs-144, looks like it has the same dimensions, the 140a version has 40 amps at 1600 or so rpm. Pics to follow.
Maybe this should be in the tech archives?
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32080
11/24/06 12:31 PM
11/24/06 12:31 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Isnt that 40 amps at 1600 alt rpms, not crank rpm's? Basically 40 amps at 500 or so crank rpms assuming a 3 to 1 pulley ratio?
Re: modern alternator swaps for BB, highest amp at idle? [Re: Von] #32081
11/24/06 12:46 PM
11/24/06 12:46 PM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
yes, I think so.
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32082
11/24/06 12:50 PM
11/24/06 12:50 PM
Middle of the US
V
Verga Offline
Verga  Offline
V
Middle of the US
Sweet. That is great info!!!
I too am interested in the CS144. I do see where someplaces list as having a bigger case than the CS130, about 14 mm bigger. But I see in your link it says the CS--- numbers refer to the size of the stator. I wonder if a bigger stator means a bigger case and if so if 14mms will matter?
Re: modern alternator swaps for BB, highest amp at idle [Re: whiplash] #32083
11/24/06 01:06 PM
11/24/06 01:06 PM
central New Jersey
dbdartman Offline
dbdartman  Offline
central New Jersey
As soon as this has been all played out, let me know & I'll make sure it's moved there!
