#32017 - 11/18/06 11:38 PM plastic fuel tank repair?
340SHORTY Offline
Loc: Kent, Wa
the main tank on my 76 dually that I bought 4 weeks ago has a gouge/hole in it. has anyone had any luck with the assorted repair kits out on the market ? results good or bad
I am truckless..
#32018 - 11/18/06 11:47 PM Re: plastic fuel tank repair? [Re: 340SHORTY]
Shian Offline
Loc: Ossineke, MI
I repaired a hole I could get almost my whole thumb in my aux tank aft of the rear axle and have been using it for almost two years now with no problem. It is call Pro Seal as far as I know you canít buy it on the civilian side, but if you donít find and thing else let me know I can get you some. I am a Blackhawk crew chief and we use it to seal just about everything on army aircraft. shian.huggler@us.army.mil
#32019 - 11/19/06 06:03 AM Re: plastic fuel tank repair? [Re: Shian]
78pwxpress Offline
Loc: Alabama
Hey Shian, is this the same stuff your talking about?
http://epdtech.com/astro/astro.htm
#32020 - 11/19/06 10:50 AM Re: plastic fuel tank repair? [Re: 78pwxpress]
340SHORTY Offline
Loc: Kent, Wa
#32021 - 11/19/06 10:15 PM Re: plastic fuel tank repair? [Re: 340SHORTY]
dave571 Offline
Loc: Carstairs, Alberta, Canada
I will say that I have patched holes in gas tanks, with fuel actually running out, with good ole JB weld.
Worth a try
www.davesmopar.com 11.85 @ 114,3890 pnds, all iron, hyd cam, 750 carb, 440, 3.73 gear Im a musician too www.davesmopar.com/davesmusic.htm
#32022 - 11/19/06 10:22 PM Re: plastic fuel tank repair? [Re: dave571]
Shian Offline
Loc: Ossineke, MI
The stuff we use is a two part, but i have heard they make it in a tube. So it could be the same stuff.
#32023 - 11/19/06 10:33 PM Re: plastic fuel tank repair? [Re: Shian]
dave571 Offline
Yes JB is a two part deal. Comes in two tooth paste tubes.
I prefer the "quick set" variety for all my on the road emergencies.
Saved another racers bottom last season.
Due to an install error, he had to ditch his tubes. It leaked like mad out of the wheel screws afterward. Mixed up some jb, and he didn't miss a round of qualifing.
Don't leave home without it.
25,740 Registered Members
192,892 Topics
Milodon part numbers
by dickdale
02/18/19 07:50 AM
wheel and tire combo
by 70moparmike
02/18/19 06:20 AM
Low oil pressure light?
by gss
02/18/19 12:41 AM
MRM this weekend
by WHITEDART
02/17/19 11:13 PM
