Thermoquad Flooding. Floats? needle/seats? #318997
05/15/09 03:02 PM
05/15/09 03:02 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
What would cause a ThermoQuad to throw gasoline everywhere? I have just finished hooking up a new throttle cable and bracket and then I tried to start the car and it ran real choppy and lots of smoke coming out of the exhaust pipes. I shut it down and then noticed gas all over the top of the carb, all around the top flaps and all down around the front and sides of the carb. It threw out quite a bit of gas (some gas went down into the intake valley).
Re: Thermoquad [Re: 68Bullit] #318998
05/15/09 03:05 PM
05/15/09 03:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Needle and seat stuck or sunk float.
Re: Thermoquad [Re: stumpy] #318999
05/15/09 04:15 PM
05/15/09 04:15 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
How do I fix?
Re: Thermoquad [Re: 68Bullit] #319000
05/15/09 05:00 PM
05/15/09 05:00 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Before this happened today, the car ran good but would be intermittent. Idle would fluctuate on it's own, and had some bogging going on while going into full throttle. Could these be some earlier signs of the needle/seats or float bowls being off?
I probably didn't need to, but I went ahead and pulled it off and drained the gas so I could get a good look at everything, and to be able to go into the carb some, if necessary. Any tips on where to start?
Re: Thermoquad [Re: 68Bullit] #319001
05/15/09 07:50 PM
05/15/09 07:50 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Wow. I recall seeing alot more people on this site that are using a TQ. I know there are some folks who could help out, I thought.
Re: Thermoquad [Re: 68Bullit] #319002
05/15/09 08:20 PM
05/15/09 08:20 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
Eric, I just emailed you about the over-rich running of the carb, David.
Re: Thermoquad [Re: DEMONSIZZLER] #319003
05/15/09 08:39 PM
05/15/09 08:39 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Hi Demonsizzler, I was just wondering why you wouldn't post your answers about the ThermoQuad on here instead of PMing or Emailing?
It would help other Thermo owners now and in the future.
Re: Thermoquad [Re: boydsdodge] #319004
05/15/09 10:34 PM
05/15/09 10:34 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Well ...I will post for all to see
The chances are VERY GOOD that this prob is sunken floats. I will dig-up the brass floats # and post it later.
The float issue on the TQ is very famous. Other than a MALadjusted secondary air-valve .... the problem caused by these bad floats are majorly complained about.
Re: Thermoquad [Re: dOc !] #319005
05/16/09 04:53 AM
05/16/09 04:53 AM
Texas
6packattk Offline
6packattk  Offline
Texas
If I recall they had fiber floats and if they get old, soak up fuel and sink,brass ones would be a permanant fix.I always had trouble with leather accelerator pumps too,then they went viton,leather would curl up and give ya the big back fire when you tried to floor it.Took me years to figure out air door setting,do it by feel now by pressure tapping on it and how lightly it closed.Have not ran thermobog since 80`s on my several 440 new yorkers......
Re: Thermoquad [Re: 6packattk] #319006
05/16/09 05:15 AM
05/16/09 05:15 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I was looking for this topic before I hit-the-hay ....
Most of the TQ's had "plastic" floats that did not need to be "old" to sink. Seems like some of the alky blend fuels did them in.
ACC pumps ? .... I have done more than my share of the Plastic-Fantastics ....and honestly ...I have never had to need to replace one of those.
ThermoBog ? ... ... you calling it that - you STILL could not have figured that AV out.
ALL you need is that new-and-improved AV tool to tweak-it-right. Available from yurrs-truly !
Join the ThermoSquad ....and Blast-da-Bumz !
Re: Thermoquad [Re: dOc !] #319007
05/16/09 05:19 AM
05/16/09 05:19 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Seems like I can not edit that other post .... I have not forgotten about getting the float #'s. I have a box that is in my trailer ... that those have to be in there.
Later today.
Re: Thermoquad [Re: dOc !] #319008
05/16/09 06:13 AM
05/16/09 06:13 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'm surprised no one mentioned a leaking o-ring, use to happen all the time.
Re: Thermoquad [Re: gdonovan] #319009
05/16/09 09:26 AM
05/16/09 09:26 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
If the gas is on the top O ring or jet wells leaking probably won't be the problem.
Another thing to check is the float level. That is measured WITH THE GASKET INSTALLED! So you may have them set too high.
Rug_Trucker
SFC. Mid TN Thermosquad
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Thermoquad Flooding. Floats? needle/seats? [Re: 68Bullit] #319010
05/16/09 10:20 AM
05/16/09 10:20 AM
I'd put a good filter ahead of the carb and a new needle/seat
Re: Thermoquad Flooding. Floats? needle/seats? [Re: RapidRobert] #319011
06/07/09 02:50 PM
06/07/09 02:50 PM
germany
440sat72 Offline
440sat72  Offline
germany
i dont know wether you have fixed that problem already but mine did the same thing when running without a fuel pressure regulator. my mechnical fuel pump cranked out 8PSI of pressure which was way too much for the TQ to handle. put a fuel pressure regulator between pump and car, adjusted it to 4.5 PSI and everything was fine.
Re: Thermoquad Flooding. Floats? needle/seats? [Re: 440sat72] #319012
06/07/09 11:05 PM
06/07/09 11:05 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Thanks for following the thread Michael. I was wondering about the fuel pump when someone else said that it could be pushing to much psi.
Can anyone tell from this picture if this pump appears to be a pump with too much psi?
Re: Thermoquad Flooding. Floats? needle/seats? [Re: 68Bullit] #319013
06/07/09 11:15 PM
06/07/09 11:15 PM
that is a stock(airtex type I believe) pump. got a vacuum gauge handy w the neoprene adapter to fit it to your fuel line as most have a psi scale to use also but I will opinionate that excessive psi is not the problem.
Re: Thermoquad Flooding. Floats? needle/seats? [Re: RapidRobert] #319014
06/07/09 11:31 PM
06/07/09 11:31 PM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Good deal. Thanks Robert. Now, I'm off to check the float levels.
Anyone help with how to check the levels on a TQ? I know how to with a Holley but still learning on the TQ.
Re: Thermoquad Flooding. Floats? needle/seats? [Re: 68Bullit] #319015
06/07/09 11:47 PM
06/07/09 11:47 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Top off upside down. Measure from the gasket!
Re: Thermoquad Flooding. Floats? needle/seats? [Re: 68Bullit] #319016
06/08/09 09:39 AM
06/08/09 09:39 AM
texas
W
Warrant_Officer Offline
W
texas
Had the same problem with my carb, turned out that the floats were way off..start there and trouble shoot as suggested.
al
