Another Question #316136
05/12/09 06:36 PM
05/12/09 06:36 PM
Anonymous OP
Anonymous OP
Sorry for all the questions but, I am trying to plan a 440 build and don't want to mess up too bad. Anyway, does anyone know what the specs are for a stock 72 440? Are all the 440 cams the same or were there different ones? If different ones, what are there specs?
Mike
Re: Another Question #316137
05/12/09 06:51 PM
05/12/09 06:51 PM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Another Question [Re: 72roadrunnergtx] #316138
05/12/09 09:52 PM
05/12/09 09:52 PM
Anonymous OP
Anonymous OP
Thanks for the info. Any idea on lift? What would be a good replacement cam for stock or slightly larger?
Mike
Re: Another Question #316139
05/12/09 10:39 PM
05/12/09 10:39 PM
I’m sure you will find no shortage of camshaft recommendations here, I chose the MP “resto six-pack three-bolt” for my project. Basically a reissue of the original camshaft. There is also a reissue of the one-bolt HP cam used in these big blocks then. BTW, same grind.
From the 09' Mopar Performance catalog
Re: Another Question [Re: 72roadrunnergtx] #316140
05/12/09 10:42 PM
05/12/09 10:42 PM
scratchnfotraction Offline
a lunati voodoo cam works good for stock
there are a single bolt cam and a 3 bolt cam
if you want a gear drive you need the 3 bolt cam
