Page 3 of 3 1 2 3
Re: What do I do with this???? clogged head? carbon? [Re: dirtybee] #314635
05/12/09 07:21 PM
05/12/09 07:21 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: What do I do with this???? clogged head? carbon? [Re: dirtybee] #314636
05/12/09 07:39 PM
05/12/09 07:39 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
inside the valve springs there should be some black rubber cup shaped seals over the valve stems. if they are hard, they need replaced. was the motor running ok before?
yep, ran fine, except the carb leaked. and leaked, and leaked.
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314637
05/13/09 01:13 AM
05/13/09 01:13 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
You ought to send that carb to Hotroddave40 he loves those Strombergs!
Re: What do I do with this???? clogged head? carbon? [Re: Rug_Trucker] #314638
07/22/09 12:07 PM
07/22/09 12:07 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I still need an aluminum manifold and carb for this thing. Anyone reccomend a manifold brand type that I can buy that has no cross over??? and what carb would you use. I am open to buying one here. Just need it to run decently!
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314639
07/22/09 12:14 PM
07/22/09 12:14 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
my Edelbrock doesn't have a crossover tube, but it's a Magnum manifold. I wonder if the LA manifold has one or not? There's a manifold in Sac with some machine work for $90:
http://sacramento.craigslist.org/pts/1281401459.html
Page 3 of 3 1 2 3
