Page 2 of 3 1 2 3
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314615
05/12/09 12:09 PM
05/12/09 12:09 PM
Dave I just had a 318 2bbl & the crossover was not heating(should be able to put your finger on the crossover pasage & feel heat starting after several minutes) & I had opened up the carb(from hell) 4 times(not kidding) & it still wasn't right so I swapped to a streetmaster alum intake and an eddy 1406(w elec choke) & now starts excellent/runs fairly good after changing the metering rods one time. I left the clogged heat riser passages as is. imo Even though it looks nasty I would not mess with them(cant get anywhere near all of it out without taking off the heads to do it right & could loose pieces into the oil or the chambers with catastrophic results
Re: What do I do with this???? clogged head? carbon? [Re: RapidRobert] #314616
05/12/09 12:17 PM
05/12/09 12:17 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thats the problem, I was concerned about it getting into the valley and made sure that didnt happen, but didnt worry about it getting any where else. It ran OK, not great before, but it ran good enough. Now I am wondering if I need to pull the engine and just rebuild it. or at least the heads.
Re: What do I do with this???? clogged head? carbon? [Re: RapidRobert] #314617
05/12/09 12:20 PM
05/12/09 12:20 PM
scratchnfotraction Offline
withRR
leave well enuff alone
you can change the seals without R&R the heads easy enuff when the engine is out
I ran plenty of JY engines worse than that
change the seals and button it back together and hope ya dont already have some loose carbon floating around on start up
if $ and time are on your side then by all maens do it right and R&R them and get a valve job
bet the exhast valves have pitting on the seat now anyways,IMO
slam it and run it,I would!
runwhatyabrung
Re: What do I do with this???? clogged head? carbon? [Re: Rug_Trucker] #314618
05/12/09 12:36 PM
05/12/09 12:36 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Like said above most of your after market performance manifolds are blocked any way so it would be of no advantage to go through the work to chip it out and risk getting carbon spread through the engine.
Not so! My holley SD, Eddie LD340, LD4B, Offy etc have exhaust crossovers. Your Crosswind, Airgap etc. don't. We are talking about a truck here, not a racecar.
I run with mine blocked off on my 360. It is an aluminum intake. It is OK even down to 2* But that is aluminum! Not iron! Gonna drive in the winter up there in Idaho, and Northern Nevada with an iron intake? Do the job right.
I said most. And I know for a fact that my LD340 is blocked (cast) and has no choke well accommadation. How hard is it to look at the intake and make sure? Also very easy to put an electric choke on and it will help emensly Not perfect by any means but they do work.
Re: What do I do with this???? clogged head? carbon? [Re: MoparforLife] #314619
05/12/09 12:41 PM
05/12/09 12:41 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I can do that easy enough, thats no issue. i am more worried about the issues I may already caused by drilling out most of the crud. If I am safe, then buying the correct manifold to make it better is no issue. I just dont want to have to replace the engine or get into any major cost factors like doing the heads. But at the same time, its exposed and easy to get to, before I put all newly painted sheet metal around it.
Re: What do I do with this???? clogged head? carbon? [Re: MoparforLife] #314620
05/12/09 12:46 PM
05/12/09 12:46 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Moparforlife aluminum as I am sure you know will warm up lots faster than an iron one. Especially with hot oil splashing off the cam. That is why my Offy is plugged on my work van.
Dave I've never seen a Mopar head that didn't have sloppy guides. If you have it apart might as well do it right.
I am going through this same stuff on a slant that lost oil pressure. I looked at the cam when replacing the crank and bearings. Lifters look fine, lobes have weird looking pits. Changed water pump as the factory one was still there. Doing the freeze plugs, new oil pump, pickup, timing chain etc.........sometimes things snowball
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314621
05/12/09 12:46 PM
05/12/09 12:46 PM
Upper Midwest
Upper Midwest
You are fine if you made sure not get any debri into the valley and make sure to clean out any that did. Put it together and run and change the oil and filter after running. Big thing is keeping the particles out of the engine.
Re: What do I do with this???? clogged head? carbon? [Re: MoparforLife] #314622
05/12/09 12:53 PM
05/12/09 12:53 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
This is the manifold I had sitting here. I just bead blasted it an dpainted it. The original valve covers are going back on these were just to keep it clean while I painted the valve covers.
This manifold does have the cross over.
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314623
05/12/09 12:53 PM
05/12/09 12:53 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
manifold
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314624
05/12/09 12:54 PM
05/12/09 12:54 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
cross over, partially cleaned out? driver side
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314625
05/12/09 12:55 PM
05/12/09 12:55 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
pass side
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314626
05/12/09 12:59 PM
05/12/09 12:59 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
So, my options are
1: button it back up and leave it and hope for the best and buy a manifold that is aluminum and hope it work.
or
Pulle the heads and do a valve job ont he heads. and upon doing so, that means the cross over is now corrected.
then ad a timing chain since I am in thre
a water pump
then I can use this manifold or should I still upgrade?
what else should I replace or do at thta point and what does a valve job cost.
I have an engine builder who buildt both of my big blocks. I am not sure if he just does this small stuff. Is it something I can do, or ????
Thanks Dave
or option #3. should I find a nice running 360 and throw it in it, or am I back int he same boat as I am here, not knowing what I am into.??
Re: What do I do with this???? clogged head? carbon? [Re: scratchnfotraction] #314627
05/12/09 01:02 PM
05/12/09 01:02 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
withRR
runwhatyabrung
I have a question, whats R&R stand for? and the seals you are speaking of, can I do those as it sits now, or are you talkign about removing the heads and redoing the valve seals?
Thanks dave
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314628
05/12/09 02:25 PM
05/12/09 02:25 PM
Upper Midwest
Upper Midwest
R&R is remove and replace
If the timing chain has not been replaced now is the time to do it and be safe. I would highly recommend it.
Sorry about my previous posts on the intake cross over. I thought that I had read that it was an aftermarket intake you were putting on it. I would definitely use the composite type gaskets on it though not the tin ones.
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314629
05/12/09 03:12 PM
05/12/09 03:12 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Dave, just clean it out good with a shop vac and run it. Sounds like you are there now. This is common on LA engines to build up the carbon. Just adjust the choke correctly and get it hot when driving, no short trips and shutting it off.
Re: What do I do with this???? clogged head? carbon? [Re: MoparforLife] #314630
05/12/09 03:16 PM
05/12/09 03:16 PM
take a vac to the plug hole on the 2 cyl that could have gotten some carbon in them and turn the cranck and push the piston up and suck any thing in there out slam it together and get er done
I would put a t-chain it it for sure while its out,I slam the 2 back freeze plugs in it also,just look at the rest and change if needed
while the intake is off and the dist out see if there is any play in the block bushing for the itermed shaft...most the time I pop a new one in just cause it in the whole core plug kit
I R&R the oil filter plate and replace that gasket and drill 4 more holes in the plate for good measure
clean,paint it with 3 cans dupli coler hemi orange,talk to it,cut/smash knuckles and bleed right in to the engine for mojo to the mopar gods,cuss alittle,dance a jig holding a rattlesnake and bible and oh!!!
my bad,,got carried away
runwhatyabrung
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314631
05/12/09 04:57 PM
05/12/09 04:57 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you want that thing done and are wondering about the stem seals,(looks like the heads have been off at some point), you can poke the seals with a pocket screwdriver through spring while the v/cvers are off to find if they're soft still or rock hard. It will give you a quicky piece of mind. Or are ya done already?
Re: What do I do with this???? clogged head? carbon? [Re: scratchnfotraction] #314632
05/12/09 05:00 PM
05/12/09 05:00 PM
clean,paint it with 3 cans dupli coler hemi orange,talk to it,cut/smash knuckles and bleed right in to the engine for mojo to the mopar gods,cuss alittle,dance a jig holding a rattlesnake and bible and oh!!!my bad,,got carried away
Just slightly
Re: What do I do with this???? clogged head? carbon? [Re: buildanother] #314633
05/12/09 05:12 PM
05/12/09 05:12 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
POKE WHAT? OK, what seals are they, what do they look like. I will check them out.
No, not done, got too frustrated and went back to what I know and started some body work ont he tail gate, radiator support and bed
and put doen some primer on a chest style coke machine that I a making a cigar humidor out of.
Re: What do I do with this???? clogged head? carbon? [Re: RUMBLON] #314634
05/12/09 07:01 PM
05/12/09 07:01 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
inside the valve springs there should be some black rubber cup shaped seals over the valve stems. if they are hard, they need replaced. was the motor running ok before?
Page 2 of 3 1 2 3
