Which A arm for 1970 Kelsey Hayes 4 piston #311718
05/08/09 02:04 PM
05/08/09 02:04 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
To put a Kelsey Hayes 4 piston setup on my 69 Dart can I use my existing (10" drum) A arm or do I need to change it out .
Re: Which A arm for 1970 Kelsey Hayes 4 piston [Re: Dart6pak] #311719
05/08/09 03:07 PM
05/08/09 03:07 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Your upper control arm is the same for drum brakes, or disc brakes.
Leave it alone.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Which A arm for 1970 Kelsey Hayes 4 piston [Re: hemi71x] #311720
05/08/09 03:13 PM
05/08/09 03:13 PM
Leave it alone.
Re: Which A arm for 1970 Kelsey Hayes 4 piston #311721
05/08/09 03:47 PM
05/08/09 03:47 PM
fyi, iirc(been awhile since I did one) the disc spindle will use 9/16"(lower) bolts as opposed to the 1/2" ones on the drum spindle/LCA but you can drill out the orig drum LCA to use 9/16" bolts to fit the disc spindle. The lCA has plenty of material & it is real soft & very easy to drill. If you are not rebuilding everything you could pull the LCA & redrill it out dead straight on a drill press in 2 minutes. I would use the correct puller for this as opposed to a pickle fork & if you put your ride height back exactly to where it orig was you would not even have to realign it.
Re: Which A arm for 1970 Kelsey Hayes 4 piston [Re: RapidRobert] #311722
05/08/09 04:07 PM
05/08/09 04:07 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The spindle does not directly attach to the LCA on a Mopar. It bolts to the lower ball joint....
Re: Which A arm for 1970 Kelsey Hayes 4 piston [Re: Jim_Lusk] #311723
05/08/09 04:15 PM
05/08/09 04:15 PM
Yes my mistake, I meant to say redrill the LBJ out to 9/16" not the LCA
Re: Which A arm for 1970 Kelsey Hayes 4 piston [Re: RapidRobert] #311724
05/08/09 05:03 PM
05/08/09 05:03 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
You are correct, sir.
Stan
