440 Bore Question.
#311533
05/08/09 09:56 AM
05/08/09 09:56 AM
I have a 1972 440 that I am planning a rebuild for. Is there any problems or issues with boring this block .060 over? This is a street engine only. Will probably never see a drag strip.
Thanks,
Re: 440 Bore Question.
#311534
05/08/09 10:04 AM
05/08/09 10:04 AM
RapidRobert
Most likely you would be good but I(myself) would have it sonic checked, the price is not prohibitive & then you will know for sure that your foundation is SOLID & it gets a person in the mindset of not assuming anything which sooner or later will end up biting a person in the a$$ usually at the most inopportune time.
#311535
05/08/09 10:09 AM
05/08/09 10:09 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
If it will clean up, you may consider boring it .055" over instead of .060". The piston selection is better for .055"-over than it is for .060". It sounds crazy, but it's true... Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#311536
05/08/09 10:22 AM
05/08/09 10:22 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
sonic check it. you want at least .150 on the major side. although some shops will tell you they know of guys running huffers, nitrous, etc. on .100 the shop that did my block tried to talk me out of the sleeve when the cylinder wall was .128, but once they understood that I wanted .150 they were happy to do the work (and increase my bill )
**Photobucket sucks**
[Re: 70Cuda383]
#311537
05/08/09 10:32 AM
05/08/09 10:32 AM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
, have it checked first to see how good it is at the bore it's at now , the major thrust side is not the only place you should be concerned with it's thickness .
[Re: JohnRR]
#311538
05/08/09 10:39 AM
05/08/09 10:39 AM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
Unless its been bored or has a bad cyl Id bore it .030.Then if it needs bored again your can recut it.Cheaper than having to sleeve it if it needs bored again.Rocky
Chrysler Firepower
