Fuel pump fro 5.9l Magnum #310494
05/06/09 08:17 PM
05/06/09 08:17 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
HI Guys...
Shopping for a fuel pump for my 5.9l Magnum
a pump mounted on the side rail of my 67 Barracuda. I have choices for 185 lph and 250 lph and 1/4 inlet and 5/16 (Prof Product from summit).....wich one to choose ?
Stock engine and computer
Thanks for the advice
Daniel
Re: Fuel pump fro 5.9l Magnum [Re: Wedgeman] #310495
05/07/09 08:11 AM
05/07/09 08:11 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
No idea on the volume needed ?
Re: Fuel pump fro 5.9l Magnum [Re: Wedgeman] #310496
05/07/09 07:35 PM
05/07/09 07:35 PM
Andrewh Offline
Andrewh  Offline
I used the MSD fuel pump from summit. Was like 95 bucks. Probably the same as the summit pump. 3/8ths inlet, 5/16's outlet.
Was fine for the 98 and up that needs the 50 psi, but don't know for the 97 and down what psi rating you need.
Re: Fuel pump fro 5.9l Magnum [Re: Andrewh] #310497
05/08/09 01:10 AM
05/08/09 01:10 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
thanks for the info..
Dan
Re: Fuel pump fro 5.9l Magnum [Re: Wedgeman] #310498
05/08/09 09:01 AM
05/08/09 09:01 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Andrew...did you install a return line or just a single feed ? I nned 45 psi....the pump pushes to 85 psi...
Dan
Re: Fuel pump fro 5.9l Magnum [Re: Wedgeman] #310499
05/08/09 07:29 PM
05/08/09 07:29 PM
Andrewh Offline
Andrewh  Offline
I used an aeromotive regulator with a return line.
I put efi rated rubber hose from the pump at the back of the car all the way up to the engine where I put the regulator.
Cut the old fuel line at the fender and used it as the return to the tank.
Got a new sending unit 3/8ths and then had feets weld a 5/16 return line into it.
With the regulator wide open, I still have 20 psi at the regulator, but I honestly think that is as low as it regulates.
It will hold 50 psi for about 2 weeks after I shut off the pump.
I could not find anyway to do it without a return line except the intank self regulated fuel pump. But since I couldn't figure out how to get it in the tank, I went this route. Overall the same cost I am sure, but this way I have less expensive parts to replace.
Re: Fuel pump fro 5.9l Magnum [Re: Andrewh] #310500
05/08/09 09:44 PM
05/08/09 09:44 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Andrew,
What would you think if I'd use a pump rated at 45psi non return line ? Aeroquip AEI 11109 ?
Daniel
Re: Fuel pump fro 5.9l Magnum [Re: Wedgeman] #310501
05/09/09 01:33 PM
05/09/09 01:33 PM
Andrewh Offline
Andrewh  Offline
I could be wrong, but I don't find that pump. I found an aeromotive one with that number.
I don't think that rating means what you think it does. You have to have a regulator to get 45 psi. That rating is just what it will pump at 45 psi back pressure.
I do not know of an efi regulator that does not have a return line.
