#308442 - 05/05/09 07:37 AM 318 engine cooling fan non-clutch where can I get one?
cudabitten Offline
Loc: eastern, pa.
Looking for a cooling fan for a 318 1974 ci engine. Cannot find a direct replacement, anyone know where I can get a new one. Everthing I found on-line has a clutch/viscous combo. I'm going to start calling junk yards. Rather have new though.
Thanks.
#308443 - 05/05/09 08:58 AM Re: 318 engine cooling fan non-clutch where can I get one? [Re: cudabitten]
stumpy Offline
Loc: Grand Prairie,Texas
Why not just get n standard Mopar fan and a spacer.
#308444 - 05/05/09 09:17 AM Re: 318 engine cooling fan non-clutch where can I get one? [Re: cudabitten]
JeffC Offline
Loc: Las Vegas
Both flex-a-lite and derale make universal rigid fans that should work for you.
69 DART 440
#308445 - 05/05/09 03:00 PM Re: 318 engine cooling fan non-clutch where can I get one? [Re: JeffC]
scratchnfotraction Offline
Loc: Florida
look for one on a /6 engine and get the space the right size
some older trucks vans have a direct drive fan blade
I went from a 4 blade on mine to a 7 blade direct drive fan
you can get the spacer at the auto store with the bolts
hit the JY and look around,I used a 7 blade fan off a amc hornet also
#308446 - 05/05/09 05:46 PM Re: 318 engine cooling fan non-clutch where can I get one? [Re: scratchnfotraction]
MoparforLife Offline
Loc: Upper Midwest
Shouldn't be that hard to find a fan that fits. All are pretty much interchangable other than the ones mounting on the back side of the clutch which require the large center hole and larger mounting spacing.
#308447 - 05/05/09 06:01 PM Re: 318 engine cooling fan non-clutch where can I get one? [Re: MoparforLife]
volaredon Offline
Loc: ILLINOIS
They used that setup past 74 my 78 Fury Sport (also 318) with factiry AC also has the 4 blade solid fan. Might help knowing that you can broaden your search a bit.
25,738 Registered Members
192,835 Topics
1971 HEMICUDA HISTORY SEARCHING.. BS23R1B CAR
by 71redcuda
02/16/19 03:46 AM
6.4 BGE block
by HOTMOPR
02/16/19 12:11 AM
Couple Pertronix questions....
by gss
02/15/19 11:00 PM
Adopt a pet
by Superfreak
02/15/19 10:43 PM
