Can magnum H2O pump/accesories fit on LA block?
#307420
05/04/09 11:37 AM
05/04/09 11:37 AM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I think the water pump spins in the opposite direction on a magnum as opposed to the LA style but I was wondering if I could use the water pump housing and all accessories from a magnum engine and use them an an LA block??? I am using magnum heads on the LA block if it makes a difference... TIA TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
Re: Can magnum H2O pump/accesories fit on LA block?
[Re: tpabayflyer]
#307421
05/04/09 12:44 PM
05/04/09 12:44 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
yes and no. IIRC on the magnums there's addional bosses on the engine block for the PS pump. if you're using PS, you'll need to cobble something together, if not, you'll have to figure out a custom belt routing and belt length.
[Re: goldmember]
#307423
05/04/09 03:17 PM
05/04/09 03:17 PM
patrick
Grand Haven, MI
when clair davis on the board here converted his 340 to a mag serpentine setup, he had a lot of hassle with the PS, IIRC according to him both the ram and van parts bolted to the block.
[Re: goldmember]
#307425
05/05/09 12:24 AM
05/05/09 12:24 AM
tpabayflyer
Tampa, FL
O.K. thanks fellas... I just may give it a whirl with a 318... TBF
