Re: Which 4 BBL manifold & carb 4 project-pics attached? [Re: RUMBLON] #306548
05/05/09 05:21 PM
05/05/09 05:21 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
another one for just because. hows the valvetrain look to you guys.
Re: Which 4 BBL manifold & carb 4 project-pics attached? [Re: RUMBLON] #306549
05/05/09 05:22 PM
05/05/09 05:22 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
they just had this thing crimped at the end. EGR???
Re: Which 4 BBL manifold & carb 4 project-pics attached? [Re: RUMBLON] #306550
05/05/09 05:30 PM
05/05/09 05:30 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
OK, JUST ONE MORE LOOK PRETTY CLEAN?
Re: Which 4 BBL manifold & carb 4 project-pics attached? [Re: RapidRobert] #306551
05/05/09 06:58 PM
05/05/09 06:58 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
The top one has the thermostat housing clocking different for an A/C application. I'd consider a 1&3/8" primaries thermoquad from Demonsizzler.
By the way, O tried to PM him to see what a carb would cost and his inbox is full. I will try a thread notification.
Re: Which 4 BBL manifold & carb 4 project-pics attached? [Re: RUMBLON] #306552
05/05/09 08:25 PM
05/05/09 08:25 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
Sent you an email and cleaned out my pm box, David.
ThermoQuads:stock, street/strip and race; 800/850 cfm's, 860/910 cfm's and 1,000 to 1,060 cfm's. New parts for all OEM 1971-1984, Competition Series and SuperQuad carbs and custom fabricating. Carbs bought and sold. Consulting on pre-purchases so you get the right carb the first time.
Re: Which 4 BBL manifold & carb 4 project-pics attached? [Re: DEMONSIZZLER] #306553
05/06/09 01:51 AM
05/06/09 01:51 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Re: Which 4 BBL manifold & carb 4 project-pics attached? [Re: DEMONSIZZLER] #306554
05/06/09 01:52 AM
05/06/09 01:52 AM
Woodbridge,CA
NAS Backyard Offline
Woodbridge,CA
Dave, the inside of that engine looks great, I wouldn't touch it. If you go with a TQ I got one I will give you, free.
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: Which 4 BBL manifold & carb 4 project-pics attached? [Re: NAS Backyard] #306555
05/06/09 02:51 AM
05/06/09 02:51 AM
Maryland
reno340 Offline
reno340  Offline
Maryland
I would just use the non-EGR manifold and get a spacer and put an Edelbrock on it. You will probably hear some on here say it won't work out but I added the spacer and put an Edelbrock on my '72 340 and it runs fine. Not a killer combo but the carb runs fine and reliably. If you don't want to do that just put on a spread bore Holley (won't need the spacer)
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Which 4 BBL manifold & carb 4 project-UPDATED? [Re: RUMBLON] #306556
05/06/09 03:40 PM
05/06/09 03:40 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thanks for the advise. I have sand blasted the early mod 4 barrel manifold and will see what carb I can afford.
Re: Which 4 BBL manifold & carb 4 project-UPDATED? [Re: RUMBLON] #306557
05/06/09 08:05 PM
05/06/09 08:05 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
OK, so here are the valve covers and manifold that I decided to use, the non EGR older one.
I also found this in my parts stash, its an Edelbrock carb. has the numbers #1407 on the side and looks like 0236???? any idea what CFM this is and why wont this work on here??? Its obviously too low and hits the manifold on the side. Can a spacer be used to lift it???
And I know the engine is not original, but what valve covers appear more original for this truck??? I painted and sand blasted both sets.
Re: Which 4 BBL manifold & carb 4 project-UPDATED? [Re: RUMBLON] #306558
05/06/09 08:05 PM
05/06/09 08:05 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
manifold
Re: Which 4 BBL manifold & carb 4 project-UPDATED? [Re: RUMBLON] #306559
05/06/09 08:06 PM
05/06/09 08:06 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
the whole group
Re: Which 4 BBL manifold & carb 4 project-UPDATED? [Re: RUMBLON] #306560
05/06/09 09:08 PM
05/06/09 09:08 PM
eddy 600 cfm manual choke. 0236 is the date code. A spacer will fix you up
Re: Which 4 BBL manifold & carb 4 project-UPDATED? [Re: RapidRobert] #306561
05/06/09 09:41 PM
05/06/09 09:41 PM
My mistake, that is a 750 not a 600
Re: Which 4 BBL manifold & carb 4 project-UPDATED? [Re: RUMBLON] #306562
05/07/09 09:15 PM
05/07/09 09:15 PM
Maryland
reno340 Offline
reno340  Offline
Maryland
Dave,
You also need the spacer because the manifold is for a spread bore carb (primary butterflies are smaller than the secondaries) and the Eddy is a square bore (all 4 butterflies are the same size)
Re: Which 4 BBL manifold & carb 4 project-UPDATED? [Re: RUMBLON] #306563
05/08/09 02:12 PM
05/08/09 02:12 PM
Stone Mt, GA.
super gas
super gas
Stone Mt, GA.
Way too much square-bore CFM for your 318! You would only need either a 500 or 600 cfm square-bore or an 800 cfm T.Q., David.
