Nitrous users..... ring gaps #306225
05/03/09 12:50 AM
05/03/09 12:50 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Wondering you guys that use juice what you use for factors for ring gaps?
Im putting another motor together (4.375 bore) and looking for some advice on what ring gap factor to use.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Nitrous users..... ring gaps [Re: Von] #306226
05/03/09 01:27 AM
05/03/09 01:27 AM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
Total seal recomends:
Nitrous shot up to 150: Bore x .006
Nitrous shot over 150: Bore x .008
I hope this helps.
JoWeTu_6
Re: Nitrous users..... ring gaps [Re: JoWeTu_6] #306227
05/03/09 07:56 AM
05/03/09 07:56 AM
i just did my small block thats what my sheet read
Re: Nitrous users..... ring gaps [Re: Von] #306228
05/03/09 02:58 PM
05/03/09 02:58 PM
On any motor that was going to see some squeeze I would make sure that the ring gap was big enough to suit my wildess dream on how much HP I was going to feed the motor, not some small HP amount at first. I would start with .036 on the top ring and probally around the same or a little biger on the second rings it is way better to have a little to much gap on NOS than it is to have a tiny bit to little
Re: Nitrous users..... ring gaps [Re: Cab_Burge] #306229
05/03/09 06:58 PM
05/03/09 06:58 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
.045 top and .050 second.
Seen plenty of 4.500 bore stuff from Sonny with .055 on the top.
