Re: Space saver inflator bottle...... [Re: mccannix] #303405
05/03/09 10:33 PM
05/03/09 10:33 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
hmmm....definately not a Ford rim
Are the date codes and 5.5 beside the valve stem like this and all other 5.5 factory spacesaver rims.
Any chance someone at some time removed and replaced the tire
Stampings near valve stem are like the ones you show except for the date code.
Sept 17, 1969
The tire did not look like it had been replaced. It is a B.F. Goodrich D70-14 Space Saver Spare.
Re: Space saver inflator bottle...... [Re: Snoopy] #303406
05/03/09 10:46 PM
05/03/09 10:46 PM
NJ
moparply Offline
moparply  Offline
NJ
I heard the change over took place early in the 1970 model year(7.75 x 14 tire to F78 x 14 tire), Oct 69? I was questioning if the (7.35 x 14 tire- E78 x 14 tire) was used for 14" rim cars or at least intended for them? Sounds like from that early publication the 7.75 x 14 tire was for both 14" and 15" rims!
Re: Space saver inflator bottle...... [Re: moparply] #303407
05/03/09 10:53 PM
05/03/09 10:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The space saver was used on some 14" & all 15" tire cars if that is what you are after?
Re: Space saver inflator bottle...... [Re: Alaskan_TA] #303408
05/03/09 10:58 PM
05/03/09 10:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For 1971 Challenger, read this page;
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1971/71_Challenger0017.jpg
It looks like they forgot to update it.
Re: Space saver inflator bottle...... [Re: mccannix] #303409
05/03/09 11:09 PM
05/03/09 11:09 PM
Snoopy Offline
Snoopy  Offline
Terry,
Is the wheel you posted a 6-Hole?
Re: Space saver inflator bottle...... [Re: Snoopy] #303410
05/03/09 11:57 PM
05/03/09 11:57 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Yes it is a 6 hole rim
Re: Space saver inflator bottle...... [Re: mccannix] #303411
05/04/09 12:20 AM
05/04/09 12:20 AM
Snoopy Offline
Snoopy  Offline
Here is the DOT code on the D70-14 SS Spare.
BAK9 CU1 463
BAK9 = Manufacturer and Plant
CU1 = Compact Spare
463 = 46th week of 1973
I thought they stopped using Space Savers before the 74 model year. If so, it looks like someone replaced the tire.
Does anyone have a picture that shows the markings in a known F78-14 Space Saver? It would be interesting to see if there is a letter "D" stamped in the wheel like the one I have posted above.
Re: Space saver inflator bottle...... [Re: Snoopy] #303412
05/06/09 12:21 AM
05/06/09 12:21 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
on the spare.....there is a white valve cap. Is this a special cap....year selective....where can I get one?-----why is it white?
Re: Space saver inflator bottle...... [Re: Roadrunner440-6] #303413
05/06/09 09:28 AM
05/06/09 09:28 AM
MD
floyd Offline
floyd  Offline
MD
It is a special cap. It has a little built-in slot at the top that allows you to remove the shrader valve (and deflate the tire after use). Moparts member Jules the Wiper Man has them I think. They're on eBay all the time but they always want too much for them in my opinion ($10 or so for a little piece of plastic that is available new somewhere). No idea on why they're white, maybe to make them stand out as different.
Re: Space saver inflator bottle...... [Re: floyd] #303414
05/06/09 10:22 PM
05/06/09 10:22 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Email me and I will send you one.
Jules
