Re: Raising compression in a 400?
[Re: MoparforLife]
#303071
04/29/09 04:14 PM
04/29/09 04:14 PM
Posts: 4,761 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Something to ponder- the costs to machine the block and heads are not cheap. With my smogger 360 the cost of new KB107s at under $200 a set is cheaper than all the machining of a block and 2 head surfaces. I dont know what a set of 400 B pistons costs but a psiton change is better than milling to get comp.
Keep old mopars alive.
[Re: 2boltmain]
#303073
04/29/09 04:28 PM
04/29/09 04:28 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Granted it is better but not less $$$. Would you put a set of new pistons in a marginal bore??? Plus rings and bearings, + machine work to press the old pistons on and either press the new pistons on or float the rods. Not cheap or right either way but----
[Re: JohnRR]
#303075
04/29/09 05:37 PM
04/29/09 05:37 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
its aaaaaaall in the pistons.
We got 9.5 to 10 compresion Rate with same heads volume on earlier years BB and RBs
Pistons and you are done... $400-500 rate.
then mill and porting heads for extra, but main win is on the pistons.
[Re: JohnRR]
#303076
04/29/09 06:35 PM
04/29/09 06:35 PM
MoparforLife
Upper Midwest
Milling the block and the heads to raise compression in this particular case is just silly. it's going to cost more to do all that machining and in the end you end up with parts that will fit nothing else .
Just throw it together and run it till you have the money and equipment to do it RIGHT ...
Machining the heads the right way does not make them parts that will fit nothing else. Done right they are interchangable between engines. I agree that the gain will be minimal and that pistons is the right way to go but as I stated but would you put pistons in a marginal or high mileage block without boring & fitting?? I wouldn't. Nor would I put new pistons and a bore job into the engine without having the heads reconditioned and the crankshaft checked out and trued if needed. But what do I know I am just a shadetree mechanic. Right Johnahah??
[Re: MoparforLife]
#303078
04/29/09 07:46 PM
04/29/09 07:46 PM
Posts: 74,948 U.S.S.A.
JohnRR
U.S.S.A.
Lighten up Francis , Don my post was not directed at anything you said, the OP has been asking this question 30 different ways and is not getting the answer he WANTS to hear.
[Re: polkat]
#303079
04/29/09 07:50 PM
04/29/09 07:50 PM
JohnRR
U.S.S.A.
If one mills the heads .060", must something be done about the pushrods? I remember in the old days people talking about shimming the rocker shafts to make up for milling. I believe some companies made these shims. Seems to me they could be homemade from .060" stock. Right?
By the way, is there a way to tell if big block heads have already been milled?
Shimming the rocker shaft is the HACK way to make up for aggressive head and/or block milling , shims are to CORRECT for INCORRECT rocker to valve geometry.
Measure the outer row of head bolts , under the exhaust flange , stock heads would be 1.000 plus or minus a couple of thou.
[Re: polkat]
#303082
04/30/09 12:37 AM
04/30/09 12:37 AM
You use the "Lighten up Francis" ALMOST as much as you use the "Outside the box thing" Think up some new ones or crawl back under your rock PLEASE!!!!!!!
#303084
04/30/09 12:52 AM
04/30/09 12:52 AM
NachoRT74
Valencia, España
as I told... PISTONS is all you need to get the old good numbers from BBs. EVERYBODY will say you diff opinions mostly of them are not on budget just on performance, but PISTONS is the only real difference between a 330 HP from 383 and 260 HP from 400. THEN you can get some more points extra with some milling, porting and cam... or simply headers and intake, you choose. I bet you can get same 330-350 HP from a 400 than a 383 with JUST THE PISTONS and the basic resto MP HP camshaft, because IS ALL THAT 383 GOT !. CRANKSHAFT was different to, because 383 HP were mostly forged and 400 are casted, BUT a casted crank can handle it without problem. we have a "cheap" solution using KB240 pistons what are same kind of stock pistons ( casted, not forged ) but hypereutic technology/design. I woudl say is the only "cheap" solution for 400s we have out of the shelf KB can get you some forged pistons too, but a little bit more expensive than the KB240. Then you have Ross, Diamond what gives you teh option for custom built But PISTONS and yu are done. I can't think somebody wouldn't be agreed on this, being the DIRECT relation with CR, being THE REST of engine is the same than earliers. 2 advantages of 400 beside a 383... stock manifold is already SPREADBORE design, and more displacement... so who can say you can't get 330-350 HP from a 400 with just that piston change ? anyway I dunno if a KB240 could give you those 330-350 HP rate, because even they are higher than stock 400s, don't know how much they really are againts 383 ones with OEM/Stock 9.5 CR. I'm not an expert on this, just being LOGICAL.
[Re: polkat]
#303085
04/30/09 01:01 AM
04/30/09 01:01 AM
RapidRobert
Snce the block CANNOT come out I'd get some (std bore I'm assuming) KB quench dome pistons of the correct CR & mill them(& the open chambered recess's) to get quench & pull your old pistons & weigh them & hope that they are close to the KB's(if heavier lighten them) & put it together w the block in place! Your piston/bore clearance might be not perfect but this will satisfy your parameters. I'd do it in a second.
