Re: Starter Relay
[Re: 440_ci]
#302886
04/29/09 10:42 AM
04/29/09 10:42 AM
RapidRobert
Start at the battery positive & work downstream. 12V at the large terminal on the starter relay then check it a bit further at the bulkhead(pull it apart & check for corrosion. If good go inside the car & check both terminals at the ammeter. Actually from your symptoms I think I'd take a peek at the ammeter 1st.
Re: Starter Relay
[Re: Snoopy]
#302904
04/29/09 02:09 PM
04/29/09 02:09 PM
Posts: 32,907 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
The smoke from the ballast resistor is normal. It gets very hot and will burn off the coating it was made with for a little while. If your not getting power out of the bulkhead connection then either the fusible link is bad or you have a bad connection at the bulkhead. It's that simple.
