EGR on Magnum eng #302210
04/28/09 06:40 PM
04/28/09 06:40 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
HI
Putting headers in my a-body to fit a 5.9l Magnum,
Can I just plug the EGR hole in the plenum and cancel the valve ? or what else ?
Daniel
Re: EGR on Magnum eng [Re: Wedgeman] #302211
04/28/09 10:13 PM
04/28/09 10:13 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Anyone ? lol
Re: EGR on Magnum eng [Re: Wedgeman] #302212
04/29/09 12:51 AM
04/29/09 12:51 AM
No expert on Magnums, but I thought I heard they didn't have an EGR? Maybe I'm thinking smog pump.
Anyway, if it does, plug it if not using the stock computer and it's tuning.
Re: EGR on Magnum eng #302213
04/29/09 08:39 AM
04/29/09 08:39 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
96-up don't. 95-down do....
2017 Grand Cherokee Overland
Re: EGR on Magnum eng [Re: patrick] #302214
04/29/09 08:46 AM
04/29/09 08:46 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Yes I am using the stock computer.
Daniel
Re: EGR on Magnum eng [Re: Wedgeman] #302215
04/29/09 11:16 AM
04/29/09 11:16 AM
I don't know how the computer will react. It may be smart enough to adapt. Try it and see. Worst case, you'll just have to revert back. EGR doesn't affect WOT performance if you keep it, btw.
I think E'berg mentioned keeping it as a performance enhancer awhile back-something to do with the timing. Email him at Mopar Action's site.
Re: EGR on Magnum eng #302216
04/29/09 12:40 PM
04/29/09 12:40 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Good idea
Re: EGR on Magnum eng [Re: Wedgeman] #302217
05/04/09 03:48 AM
05/04/09 03:48 AM
Missouri
NFURY8 Offline
super street
NFURY8  Offline
super street
Missouri
You can dump it and plug it. I did this on my 5.2 swap. I actually swapped in a 98 intake, which already has the EGR plugged up, and welded the bung on the headers closed. Then I cut out all the wiring. Everything runs fine. The computer will store a code for fault in the EGR circuit, but it will not turn on the MALF light, if you are using one. I have one hooked up for troubleshooting while still shaking down the system.
C-Body DryDock Bigger is Better!
