Spark Plugs Question #301106
04/27/09 02:50 PM
04/27/09 02:50 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
What spark plugs should I run in my 505ci wedge? It is an iron headed 11.5 compression street car. I am currently using Accel 134 plugs.
Re: Spark Plugs Question [Re: Harley] #301107
04/27/09 03:10 PM
04/27/09 03:10 PM
Accell is a good(but $$$) plug. Are you wanting to go to something cheaper or a different heat range?. what are your plugs showing now?
Re: Spark Plugs Question [Re: RapidRobert] #301108
04/27/09 03:56 PM
04/27/09 03:56 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
I am running a tunnel ram with 2 holley 750’s. They are coming out a little dark. I have been playing with the idle mixture screws and am having a hard time dialing the idle in. I was thinking about putting in a hotter plug to see if it would help the idle.
Re: Spark Plugs Question [Re: Harley] #301109
04/27/09 04:13 PM
04/27/09 04:13 PM
The BEST plug info chart is on Mancinis website
Go with NGK's they say use and you will be happy
Re: Spark Plugs Question [Re: ] #301110
04/28/09 09:31 AM
04/28/09 09:31 AM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
Re: Spark Plugs Question [Re: Harley] #301111
04/28/09 09:40 AM
04/28/09 09:40 AM
Harly if your plugs aren't fouled out(& it doesn't sound like they are) I would attack the carbs.
