69 Charger not charging. #299015
04/25/09 01:57 PM
04/25/09 01:57 PM
Indianapolis, IN
TurquoiseRT Offline OP
super gas
super gas
Indianapolis, IN
Back story. Came home last month and when I pulled into the driveway a big blue puff of smoke came up out of the right side of the engine compartment. Car was not charging at that point so I took the alternator out and had it test, it is bad.
So, I buy a new one (dual terminal) and install it. Car wont even start, no nothing. I start checking connections and the blue wire on the second bulkhead connector, bottom left had bubbled and melted. So, I cleaned the connection and it started. Now it is not charging and left me stranded last night.
I am not sure where to start checking with my voltmeter. there is voltage at the alternator main post (11.69) voltage at the field (10.74) , voltage at the ballast resistor (left 11.22) (right 8.05*****) and voltage at the regulator (10.72 Fld) (11.22 Ign)
The 8.05 off the ballast resistor scares me but I am not sure what it should be. It is reading 2.0 ohm.
Thoughts?
Re: 69 Charger not charging. [Re: TurquoiseRT] #299016
04/25/09 02:07 PM
04/25/09 02:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check your fuseable links( I hate those things, they
could have just fused it)
Re: 69 Charger not charging. [Re: MR_P_BODY] #299017
04/25/09 02:46 PM
04/25/09 02:46 PM
you have the later electronic flat voltage regulator? These are your readings at idle w it not charging?. What is the batt voltage?
Re: 69 Charger not charging. [Re: RapidRobert] #299018
04/25/09 02:53 PM
04/25/09 02:53 PM
Indianapolis, IN
super gas
super gas
Indianapolis, IN
sorry, no. I have the boxier voltage regulator due to the electronic ignition.
Yes, these are the readings at idle. Battery is at 11.97 when I start but is quickly drawn down to 11.4 or below.
Re: 69 Charger not charging. [Re: TurquoiseRT] #299019
04/25/09 02:58 PM
04/25/09 02:58 PM
& you grounded the other alt field terminal
Re: 69 Charger not charging. [Re: RapidRobert] #299020
04/26/09 09:33 PM
04/26/09 09:33 PM
Indianapolis, IN
super gas
super gas
Indianapolis, IN
huh, well.... that was it. The ground wire had come off the field and I had not noticed there had been one on there.
It is a charging Charger now.
Thanks guys.
Jeff
