Re: 400/512 combo
[Re: RapidRobert]
#298714
04/25/09 10:55 AM
04/25/09 10:55 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I dont like the 4.15 or larger crank in the B wedge if it's a street engine. The pistons are very short. As a result, as things wear, they will rock a lot. I would not recommend a quench tighter than .040 on them, and the rings (including the all important oil set) will not be as good for nearly as long. So the biggest I'd go is 3.915 stroke. JMO.
