will the build sheet tell me what gears??? #297842
04/23/09 10:14 PM
04/23/09 10:14 PM
colorado
chargermop Offline OP
colorado
I have a 72 dart and want to know what gears came in it. I have the build sheet what do I look for??
Re: will the build sheet tell me what gears??? [Re: chargermop] #297843
04/23/09 10:29 PM
04/23/09 10:29 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
second line from the top. Should say Axle about 3-5 boxes over and a two digit number. That number tells you gear ratio.
The next box will have SG above it.
Re: will the build sheet tell me what gears??? [Re: RobX4406] #297844
04/23/09 10:35 PM
04/23/09 10:35 PM
colorado
colorado
ok under axle it says 181
Re: will the build sheet tell me what gears??? [Re: chargermop] #297845
04/23/09 10:37 PM
04/23/09 10:37 PM
colorado
colorado
and the next box is for wheels???
Re: will the build sheet tell me what gears??? [Re: chargermop] #297846
04/23/09 10:39 PM
04/23/09 10:39 PM
RobX4406 Offline
RobX4406  Offline
That's probably the FIFTH line not the second line from the top.
Re: will the build sheet tell me what gears??? [Re: RobX4406] #297847
04/23/09 11:14 PM
04/23/09 11:14 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
