5.7 Hemi Dual quad w/600 carbs....initial carb set up #297427
04/23/09 01:59 PM
04/23/09 01:59 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Came across this 5.7 Hemi dual quad intake and decided to try it out with a couple 600 AFBs/Edelbrocks.
They are the electric choke versions, supposed to be calibrated lean per E's site...All the choke stuff will be gone from the front carb and the vacuum holes drilled/tapped/plugged.
Been considering going with Edelbrock's "4 percent rich" calibration for the manual choke carbs as a starting point for jets and metering rods, just to make sure I'm starting with something halfway safe.
Bad idea? Not sure if I'm overthinking it...normally I'd start with stock jetting but when the mfr admits it's deliberately lean, I'm tempted to try to correct it before I even get started.
Anyone run a similar dual quad setup...what kind of headaches to expect? I can't imagine it being too far off from a 340 or 360....
Think I can get away with 1:1 linkage on a mostly stock 5.7, or will it need to be progressive linkage? It might get a stock 6.1 cam at the most, other than that no mods.
Sorry for the lousy cell phone
picture, it was the best I could do at the time...
Re: 5.7 Hemi Dual quad w/600 carbs....initial carb set up [Re: ZIPPY] #297428
04/23/09 06:47 PM
04/23/09 06:47 PM
Beavercreek, Ohio
OA5599 Offline
OA5599  Offline
Beavercreek, Ohio
Looks sweet. I would set it up similar to a 340 and go from there...
Re: 5.7 Hemi Dual quad w/600 carbs....initial carb set up [Re: ZIPPY] #297429
04/23/09 07:19 PM
04/23/09 07:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Zippy, I'd try it as is... just do a couple of short
run up's then check a couple of plugs.... looks cool
Re: 5.7 Hemi Dual quad w/600 carbs....initial carb set up [Re: MR_P_BODY] #297430
04/23/09 09:50 PM
04/23/09 09:50 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Good point Mike, there's really no break in to worry about so if it's hideously lean I can just shut it off and fix it.
I'm probably overthinking it, but haven't worked with AFBs in a LONG time and never messed with multiple carbs....
Rich H.
Esse Quam Videri
Re: 5.7 Hemi Dual quad w/600 carbs....initial carb set up [Re: ZIPPY] #297431
04/24/09 09:19 AM
04/24/09 09:19 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
which 600's are they exactly? FWIW on my 360 single 4bbl engine I needed to lean the 1406 carb out about 1 step on the primary and 2 or 3 jet sizes down on the secondary.
2017 Grand Cherokee Overland
Re: 5.7 Hemi Dual quad w/600 carbs....initial carb set up [Re: patrick] #297432
04/25/09 10:41 AM
04/25/09 10:41 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
They're 1406's, and I've stripped all the electric choke stuff off the front carb.
