Spinning a crank bearing.. What damage?
#297213
04/23/09 09:48 AM
04/23/09 09:48 AM
Posts: 4,282 Danville, NH
Mopar_Mike
Danville, NH
I am picking up a 440 block that the engine has spun a crank bearing (sellers words, could be a rod but I do not know yet) What type of damage should I expect? The engine is apart so I can inspect it. I am mostly concerned with the block and not the crank. Is it possible the block could be damaged from spinning a bearing? Thanks.
RS23L7 4-Speed
Re: Spinning a crank bearing.. What damage?
[Re: MLR426]
#297215
04/23/09 12:30 PM
04/23/09 12:30 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
If it's a spun main bearing the block would need to be line honed to correct bearing crush. In doing this you need to remember to order a new -.005 timing set during assembly. If it's a spun rod bearing, regrind crank and resize the rods big end for correct bearing crush during assembly.
logan426
Further to that, check to see if there is discoloration (blueing of the cap, rod, block or crank) as it may have altered the metallurgy of the component in question.
[Re: Mopar_Mike]
#297216
04/23/09 12:35 PM
04/23/09 12:35 PM
Posts: 30,994 Oregon
AndyF
A spun main bearing will often ruin the block.
A spun rod bearing is usually no big deal although I did totally trash an engine on the dyno once by spinning a rod bearing. The rod bearing spun which caused the piston to hit the head and then the cylinder wall split. So that engine was toast from top to bottom.
[Re: AndyF]
#297217
04/23/09 01:10 PM
04/23/09 01:10 PM
Posts: 4,799 ILL
MLR426
ILL
Also to add more if the rod or main bearing area of the crank has taken alot of heat it's possible the crank could be cracked and junk. These are all jugdement calls by all of us because we are not looking at any parts.
logan426
[Re: MLR426]
#297218
04/24/09 06:52 AM
04/24/09 06:52 AM
Mopar_Mike
Danville, NH
Thanks all for your input.
RS23L7 4-Speed
