MSD guys...
#297092
04/22/09 11:55 PM
04/22/09 11:55 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
So I picked up an MSD 6AL off craigslist, turns out some punk was running it on his honda.
as I printed out the manual for it and started reading, I see where it says to operate on a 6cyl, to cut one of the wires internal to it, and if it's a 4 cyl, to cut both (the red/blue wires inside)
assuming the kid did that (I haven't checked it yet) and both wires are cut...can the box be opened back up to repair the wires to use on a 8cyl? or should I send it back to MSD to do this fix? or should I re-sell it on craigslist to another 4banger runner, and buy a new one?
**Photobucket sucks**
Re: MSD guys...
[Re: GoodysGotaCuda]
#297094
04/23/09 09:33 AM
04/23/09 09:33 AM
70Cuda383
Marysville, O-H-I-O
Thanks goody,
I just looked at the box today, and they are indeed, both cut. but, the way he cut it, it looks like I should at least be able to dribble some soder on the wires and get them back together easy enough. its sandwiched between plastic, so I shouldn't have to worry about shorting out against the case or anything.
Re: MSD guys...
[Re: Posest]
#297097
04/24/09 07:31 AM
04/24/09 07:31 AM
70Cuda383
Marysville, O-H-I-O
Heck yes I would do it. What do you have to lose, as long as the solder job is good and not weak you should have no troubles.
Pretty much my thought...picked up this used box for $100. he was asking $150, but my craigs list negotiation skills took over and I got him down to $100.
so, I'm into it for $100, and if the box is fried and the guy thought he would rip me off for $100...then I guess he won! If it is fried, then I'll send it to MSD and hope the repair is less than $100, because for $200, I could get a new box
