Injection Gurus please.. #295188
04/21/09 01:44 PM
04/21/09 01:44 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Preparing to wire a 5.9l Magnum into my Barracuda..
In order to have the engine running,do I just need to attach a 12V supply to the igniton feed on the PCM ?No,9 pin.....I figured that all I need is a power supply to the mudule and hook the rest to the engine have it running? am I wrong ?
For the MAP (5volts output)and distributor (8volts output)is the PCM dropping the voltage or do I need a relay to provide 5-8 volts to the computer on these pins ?
THe pcm comes from a B350 Van (AB body)
I kept the 904 trans(beefed up), the alt circuit, starter relay etc... from the Barracuda
Thanks for all the help
Daniel
Re: Injection Gurus please.. [Re: Wedgeman] #295189
04/21/09 07:02 PM
04/21/09 07:02 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Anyone ???
Re: Injection Gurus please.. [Re: Wedgeman] #295190
04/21/09 08:19 PM
04/21/09 08:19 PM
Andrewh Offline
Andrewh  Offline
what year van did it come out of?
Re: Injection Gurus please.. [Re: Wedgeman] #295191
04/21/09 08:24 PM
04/21/09 08:24 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
the 5v is supplied by the pcm best thing to do is get some factory wiring diagrams
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Injection Gurus please.. [Re: 1969gtx] #295192
04/21/09 10:34 PM
04/21/09 10:34 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Engine comes from a "94 van, yes I have a factory shop manual
Re: Injection Gurus please.. [Re: Wedgeman] #295193
04/22/09 01:55 AM
04/22/09 01:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The 5 and 8 volts are supplied from the PCM and the PCM needs a hot 12 volts , 12 volts at key on and two grounds just to start. Ron
Re: Injection Gurus please.. [Re: 383man] #295194
04/22/09 11:55 AM
04/22/09 11:55 AM
Andrewh Offline
Andrewh  Offline
Well, for my conversion, I had to tie in the two 12 volts from start and run to the computer. You may have to do the same.
Re: Injection Gurus please.. [Re: Andrewh] #295195
04/22/09 01:19 PM
04/22/09 01:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I agree w/ Ron, you do not need to supply the 5 and 8 volts yourself, just the proper grounds and 12v feeds.
Re: Injection Gurus please.. [Re: DaytonaTurbo] #295196
04/22/09 04:35 PM
04/22/09 04:35 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
OK..
Thanks a lot guys !!!
You confirmed what I tought.....
Daniel
Any idea on a cheap fuel pump set up ?
Re: Injection Gurus please.. [Re: Wedgeman] #295197
04/22/09 05:15 PM
04/22/09 05:15 PM
Andrewh Offline
Andrewh  Offline
The msd pump from summit was under 100 bucks.
The most expensive part was the regulator.
