Re: How to replace shift shaft seal on 727 trans?
[Re: cal_gecko]
#29457
09/02/06 10:46 PM
09/02/06 10:46 PM
R U sure it is this seal and not the small kickdown one ?
You can just put a deep pan on it ...and just lower the fluid level.
[Re: cal_gecko]
#29459
09/03/06 01:05 AM
09/03/06 01:05 AM
Can you see if it is leaking on the high or low part of the shaft ?
The lower seal is a complex one. The upper seal is just a simple rubber one.
How you thought about a deep pan?
[Re: mrsmallblock]
#29461
09/03/06 01:20 AM
09/03/06 01:20 AM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
the easiest way is going to be taking the valve body out. remove snap ring and washer to remove and replace the kickdown seal. if you are careful take the kickdown rod out without removing the rooster. then you can polish the shaft because that is what kills that seal, rust and corrosion. the case seal you can knock out from the bottom and use a big c clamp and washer to draw the new seal in. i have done this many times. not too big or a deal.
howard mrsmallblock
what is 'the rooster'? I am not familiar with that term. I guess I'll see if I can get the rubber seal for the kickdown shaft too... I doubt I'll be able to find a parts store that has one in stock though.
[Re: cal_gecko]
#29465
09/03/06 01:40 AM
09/03/06 01:40 AM
The deep pan is the plan .... just have the fluid show on the TIP of the stick.
[Re: cal_gecko]
#29470
09/03/06 03:18 AM
09/03/06 03:18 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks, FluffyTwinkie!
No problem, its not all that hard to pull the valve body. It is helpful to have someone around thats done it before if you get in a jam though.
Oh and the fluffytwinkie...im thinkin im due for a new name.
[Re: mrsmallblock]
#29472
09/03/06 12:49 PM
09/03/06 12:49 PM
Posts: 374 Mo.
1100HPSmallBlock
Mo.
the rooser is actually the piece that goes through the case seal and the kickdown shaft goes throught the inside of the rooser. it has a check ball and spring that serves as the detent selector for your gears. mrsmallblock
[Re: 1100HPSmallBlock]
#29473
09/03/06 01:42 PM
09/03/06 01:42 PM
Posts: 1,913 Brunswick, Jawgia
Snailpower
Infinitely Fast Snail
Brunswick, Jawgia
IMO, the deep pan is a band aid for a bad seal on the trans. Fix it right the first time. You can do this seal replacement without pulling the valve body, dropping the pan and if the trans is clean you won't even get your hands dirty (much).
Take the kickdown and selector lever off the trans (both pinch bolts) and take a sharp pick to work the selector shaft seal out of it's hole and up the shaft. It's a press fit, so jab the pick through the top of the old seal and use leverage.
Take the new seal, lube it a little and slide it over the shaft until it sits evenly on the trans case, not cocked. Take a deep socket the same size as the seal and slide it over the shaft to rest on top of the seal. Tap the socket until the top of the seal is flush with the trans case. Re-install selector/kickdown levers.
I have done many this way. The worst I have had to do is un-bolt the trans crossmember to drop the end of the trans down for a little more room to work.
Jeff
70 Coronet- turbocharged 360/518/3.73 SG
[Re: Snailpower]
#29476
09/03/06 05:14 PM
09/03/06 05:14 PM
The deep pan is not the way to fix your problem! The seals are easy to change, just get the (KD) tool (Anderwh) listed and do it in the car. Drain some fluid out prior to doing it so you don't get covered in fluid. If you don't want to buy the tool, use a small screwdriver to pry out the old seal and a deep socket to hammer in the new seal. Next time you need a small seal for your transmission, go to you local trans shop, they should have plenty of them.
[Re: Kirk_Ingram]
#29477
09/03/06 05:15 PM
09/03/06 05:15 PM
A deeper pan that has more capacity .... filled at the same height as a stock pan ? How many larger capacity engine oil pans are approached this way ? REcalibrate your dip-stick then. And very true .... putting a deep pan on to avoid leakage is a band-aid - and it IS more proper to FIX the ailment. But to some people that are DIY ... this job could be over-their-heads. Just my
[Re: cal_gecko]
#29480
09/03/06 10:53 PM
09/03/06 10:53 PM
kd seal ? ...stop by any trans shop. They should have a bunch of them. Those seals are very rarely changed by most rebuilders.
[Re: cal_gecko]
#29481
09/04/06 02:14 AM
09/04/06 02:14 AM
Posts: 1,869 Carmichael, CA
NotEnufGarage
Carmichael, CA
I may be running by a friends transmission shop tomorrow. If so, I'll see if he has a seal. I'll PM you if I get one.
'70 Charger FE5 Daytona Clone 451/727/D60 '70 Challenger FM3 440/833/3.55SG '79 Ramcharger SE 360 '89 Shelby Dakota ‘06 PT Cruiser GT Convertible ‘07 Charger R/T Daytona ‘10 Ram 1500 ST Crew Cab
Yes, I'm a Dodge Boy. Verstehen?
[Re: John_Kunkel]
#29484
09/04/06 04:20 PM
09/04/06 04:20 PM
And the "band-aid fix" is to fill the trans with a couple quarts less.
Not a good idea. The TF, unlike the engine, can suck air if the VB-to-case mating surface is exposed to the air.
I have always wondered about that....but if that was a major "issue" - why wouldn't the OEM have put some O-rings or a gasket in there?
[Re: cal_gecko]
#29487
09/06/06 01:11 AM
09/06/06 01:11 AM
NotEnufGarage
Carmichael, CA
Sorry - my buddy usually gets them in seal or rebuild kits and he didn't have any in stock.
I've got a /6 904 you could take one out of, if you want to try reusing a used one.
[Re: NotEnufGarage]
#29488
09/06/06 10:17 AM
09/06/06 10:17 AM
Posts: 1,456 Northern CA
streetkit
Northern CA
Mark,
Last time I needed one, Autozone (of all places) had them in stock.
1973 Dodge D100
[Re: streetkit]
#29489
09/17/09 03:49 AM
09/17/09 03:49 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I did this last year. Used a tool off ebay for less than $20 Something like this one http://cgi.ebay.com/ebaymotors/KD-TOOLS-...d=p4506.c0.m245I think I have pictures of the install posted a while back too. I had to use a C clamp because of the space limitations but I fixed it in less than an hour. No need to drop the pan.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: cal_gecko]
#29490
09/17/09 04:19 AM
09/17/09 04:19 AM
Posts: 7,759 So Cal
HealthServices
So Cal
the shift shaft seal on the SuperCoupe is leaking pretty bad..
This is pretty bad...
Cleaned off.
Tool ready to remove seal...
Clamp to put pressure on seal while I turn the threads into the seal
After the tool takes hold of the seal you put the bolt into the top of the tool to pull the seal out....
click the picture for a larger view.
here is the picture of the seal removed
A closer look...
The new seal
New seal being installed with tool and clamp.
Linkage re installed.
[Re: FastbackJon]
#2324578
06/21/17 09:43 AM
06/21/17 09:43 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I am looking at replacing the shift shaft seal from the top with the extractor tool in my 1966 Charger 727.
I am hesitant in taking the two levers off (gear and throttle) from the shift shaft, not knowing if they are keyed are not. Or should I worry about this?
The throttle lever appears to be keyed but the gear lever, I can't tell. Will it just go back on the same as it came off and then I can just make minor adjustments to the horizontal rod to change shift selector (gear) position?
Thanks! they can only go on one way,youll see that when you remove them.
[Re: FastbackJon]
#2324779
06/21/17 03:36 PM
06/21/17 03:36 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Various shift levers and TP levers.
[Re: cal_gecko]
#2327049
06/26/17 05:37 PM
06/26/17 05:37 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I just use a small pick and get them out.
