difference between 318 poly 727 and bigblock??
#29245
08/06/06 09:03 AM
08/06/06 09:03 AM
Posts: 260 Clarkston, MI
wheelsup64
Clarkston, MI
What's the difference between the torqeflite used with a 65 318 poly motor and the ones mated with big block motors? I'd like to pick one up for spare parts but don't know how to tell the differences.
never mistake motion for progress.
Re: difference between 318 poly 727 and bigblock??
#29247
08/06/06 09:38 AM
08/06/06 09:38 AM
wheelsup64
Clarkston, MI
Thanks that's good reference info to have. I have a line on one already that is claimed to be from a Poly. I'll check it. Besides the numbers, what are the physical differences inside and out? Any?
[Re: 74DusterP457]
#29249
08/06/06 10:32 AM
08/06/06 10:32 AM
wheelsup64
Clarkston, MI
thanks for the reply. What I'm actually tring to do is find spare parts for my big block trans. I read in the "Chrysler Performance Upgrades" book by Frank Adkins, that "..from 62 to 64 there were two versions of the trans. The Torqueflite 6 and the Torqueflite 8, which became the A-904 and A-727 respectivly." He does not delineate any difference between the Poly, A, LA, B/RB V8s. Hence my confusion.
[Re: Dennis_K]
#29251
08/06/06 11:51 AM
08/06/06 11:51 AM
Posts: 9,336 central New Jersey
dbdartman
central New Jersey
If the trans is for a big-block, the top 2 bolt holes where it bolts to the engine will be 6.5" apart, and if its for a poly or a small block, the top 2 bolt holes will be farther apart, but I don't remember what the measurement is right off the top of my head.
FYI, SB top bolts are 7-3/4" C-to-C.
[Re: dbdartman]
#29252
08/06/06 12:30 PM
08/06/06 12:30 PM
wheelsup64
Clarkston, MI
Thanks. Do any or all of the internals interchange? How about the shift and speedo cables? Are they the same?
[Re: wheelsup64]
#29254
08/06/06 03:30 PM
08/06/06 03:30 PM
The internals of the /6, SB and BB 727 are all the same, and interchange without any problems. Tailshafts are also the same, just difference in long and short ones.(and truck tails). Bellhousing is different..
Fred
