15x7 steel wheels on 72 Demon questions. #290897
04/17/09 02:41 AM
04/17/09 02:41 AM
Ont Canada.
Hardcharger65 Offline OP
Ont Canada.
Im thinking of putting a set of 15x7 black steel wheels front and back on my 72 Demon, will they fit nicly on the front with no rubbing when im turning ?, what offset would be good for the front wheels and what size tires can i run ?. I want to install a set Goodyear Polyglas. Im running 10" manual brakes all around... any ideas would be helpfull, thanks Moparts.
Re: 15x7 steel wheels on 72 Demon questions. [Re: Hardcharger65] #290898
04/17/09 03:59 AM
04/17/09 03:59 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I have a 72 demon, stock wells.
You can fit a 225 in a tire in the front- that should fit good on 7" I am running 275 60 15's in the back on my 72 demon and it is a little tight to the wells, but that is with 8" rear wheels, so a 7" wheel with a slightly smaller tire should be just fine.
Good luck
radar
