which elctronic ign mod do you use??
#290762
04/16/09 11:05 PM
04/16/09 11:05 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
One basically a warmed over stock motor say 350-400 hp would you stay with the factory black electronic ignition module or step up to the MP orange box...Are the advantages worth it or?? Some opinions would be greatly appreciated..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
Re: which elctronic ign mod do you use??
[Re: 72N96RR]
#290763
04/16/09 11:08 PM
04/16/09 11:08 PM
Posts: 85 Rhode Island
GoodfellaHenry70
Rhode Island
I run Orange (Proudly made in Me'heco)Boxes.
I keep a black or orange box as spares in each car.
I think the black box provides steady spark up to 5000rpm and the orange good to 6500rpm.
"No big deal...It's called Advanced Dilusionary schizophrenia with involuntary narcissistic rage."
Just call me Hank.
[Re: 72N96RR]
#290764
04/16/09 11:09 PM
04/16/09 11:09 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
If you are going to buy a better box, then I'd say go with the chrome box. The orange is only marginally better than a stock one.
I am using an FBO ignition box. It has similiar specs to a crome box.
[Re: 72N96RR]
#290765
04/16/09 11:59 PM
04/16/09 11:59 PM
RapidRobert
I would not buy the orange box. Either the FBO ecu/ballast or the MP chrome box & I believe it takes the 1.25 ohm MP single ballast
[Re: MoparforLife]
#290769
04/17/09 07:57 PM
04/17/09 07:57 PM
Posts: 1,044 minnesota
president61
minnesota
There waas a write up in the Mopar mags a few years ago that stated that if your if your present ignition is working that the only real advantage to the higher priced systems is more bells and whistles. I had at teh time I read this already switched from a home recurved OEM distriutor and chrome box to a Crane HI6 and MSD billet distributor. What did I gain nothing in performance or runnability. I gained the ease of setting the advance curve (whoopty doo) as if that is something that you do every day. Once it is set it is set.
I agree that high dollar stuff is over-rated. I'm not 80 years old either. I switched my Satelite over to electronic 17 years ago using stock parts from a junk yard. I haven't had a lick of problem ever. My 383 will rev to 6000 no problem too. A friend of mine had one of those MSD boxes take a poop at the track and it set him back $250!
[Re: president61]
#290770
04/17/09 08:36 PM
04/17/09 08:36 PM
Posts: 7,506 Az
Crizila
Az
I went with a D.U.I. system. I don't need no stinking boxes, balasts, coil brackets, or anything else ignition related cluttering up my fire wall. One 12vlt wire ( and a tach wire) is all that's needed. The curve is easily adjustable and it puts out 50K+ open voltage on my distributor machine. Lights them all, every time!
Fastest 300
[Re: MoreParts]
#290774
04/17/09 10:40 PM
04/17/09 10:40 PM
Just picked up a ProComp hei dist on Ebay, $46. and a cheap Summit hei coil, no ballast. 2 wire hookup, fired right up.
#290775
04/17/09 10:44 PM
04/17/09 10:44 PM
Posts: 565 IA
landon1
IA
I have the Procomp HEI as well, but with an Accel Superstock (no ballast)...great set-up for a street car imo
'71 Satellite Sebring 440
[Re: Hotwheelsjr]
#290779
04/18/09 06:23 PM
04/18/09 06:23 PM
Posts: 4,910 new berlin wisconsin
Mr T2U
i run a MSD box without troubles. the reason i like the aftermarket boxes because you can easily add advance and retard functions from the digital boxes, and actually set them up to do it at a certain rpm, or get add on boxes for the older non digital ones. one other think people forget about multi-spark is it will usually improve idle quality especially if your AF mix isn't perfect.
perception is 90% of reality
[Re: Mr T2U]
#290780
04/18/09 07:26 PM
04/18/09 07:26 PM
I've run nothing but msd systems in my cars for years with no problems or breakdowns,same can't be said for mopar ignitions..i think its pretty sad when you need to carry spare ignition parts in the trunk for fear of a breakdown..
[Re: Azzkikrcuda]
#290782
04/20/09 04:21 PM
04/20/09 04:21 PM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
chrome box w mopar distributor, new plugs that are the correct heat range, starts great.
[Re: mark7171]
#290784
04/20/09 06:32 PM
04/20/09 06:32 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Never had a MSD. Mopar boxes can be swapped cheaply and get you home. I did have a Jacobs ProStreet on my van. That thing made the engine scream!! That was a few years ago and reliability was a big issue. If they were reliable I would get another system. If it failed you could just swap coil wires and go on your merry way. Pertronix? Where do you find extra parts when it quits in BFE? The HEI sounds like where I am going to go with the slant in my Duster.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#290785
04/20/09 07:38 PM
04/20/09 07:38 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Well,.....I've never had a Pertronix fail me yet,......logged 10's of thousands of miles on cross country runs, Hotrod Power Tours, roadraces,etc,etc,etc, year after year........but, you just keep the old points and condensor in the glove box,.....if you ever need'em. easy swap over, or you carry a spare Pertronix Hallcell......But I haven't had the need to, for years now........when I ran points, or MP electronics,.....you always needing a spare set of points, condensor, and a ballast resistor, or if you had MP electronics, you needed a spare ECU, and a ballast resistor,........no ballast with Pertronix, although I do hang one on the firewall, with non-functioning wiring, just for the "original" look,......and if I ever do have a failure, just swap in a spare hallcell, easy as changing a rotor,.....or points and condensor, and replug the ballast into the actual system, a 10 minute job at best......
In the last 30+ years, I've had my share of factory, MP, accell, MSD, etc ignition systems,......a Pertronix done "properly", IMHO outperforms the other systems in reliability, and in many cases performance as well!
[Re: rt66jim]
#290786
04/20/09 09:17 PM
04/20/09 09:17 PM
Posts: 15,193 Omaha Ne
TJP
Omaha Ne
I ran a Wells box purchased at Auzone Zone for years. Car ran 11.08 with it. I bought in to the idea it wasn't good enough. Purchased a FBO box and coil. The car still ran 11.08. If I needed a box a new box I'd go to AZ and save $50. JMO Jim
[Re: mark7171]
#290787
04/20/09 10:00 PM
04/20/09 10:00 PM
Posts: 15,478 the boonies
aarcuda
the boonies
Did away with the harness a while ago. i use the $50 all in one 75 kv E coil/distributor/box procomp vacuum advance distributor.
What a great set up. ground it. contect it with 2 wires it is making fire. Brown and blue with white stripe were the wires i use.
It is awesome. mine came with 12-intial 2o mechanical, 10-15 in the can.
comes with 12 initial???
[Re: DAYCLONA]
#290788
04/21/09 08:30 PM
04/21/09 08:30 PM
Posts: 752 MA
440beeper
MA
Just keep the old points in glovebox...you could always swap it back on the side of the road if necessary.
[Re: 440beeper]
#290789
04/21/09 08:36 PM
04/21/09 08:36 PM
Rug_Trucker
No thanks!
[Re: Rug_Trucker]
#290791
04/21/09 09:11 PM
04/21/09 09:11 PM
Posts: 15,487 Florida
scratchnfotraction
I like the pertronix in a points dist to get a little better advance curve using stock stuff been 9 yrs and no trouble yet,I have the 40,000 kv coil with it as far as finding parts for it...never had to its been 6200rpm bunch of times for me just fixed a 85 dodge van for a old man thats been broke down for a week due to the stock elect crap droped in a points dist and the pertronix is on the way for it the shop has done sucked over 350$ of him and he got 5 miles and a tow home he keeps starting it and go round the block and shut down..start it back up..he is cant believe I hooked it up for him free of charge for him to get going I told him if he keeps on the starter will need to be uped to a mini starter for it points work on a hemi with 2-4 barrels and a 4-speed and turned over some 6000 rpms for yrs whats wrong with simple now days but thats my hickabilly shade tree
[Re: scratchnfotraction]
#290792
04/21/09 09:39 PM
04/21/09 09:39 PM
i run stock boxes i get from a junkyard for 2 bucks. i had a mopar orange and it made no difference at all until it melted. didnt start any different, no more hp, i guess you get more rpms from an orange box but the highest ive ever ran my car was about 5000 just for a second or 2 while revving it.
[Re: Rug_Trucker]
#290795
04/22/09 10:41 AM
04/22/09 10:41 AM
Posts: 271 Dallas, Wisconsin
BurntOrange
Dallas, Wisconsin
A friend had a Pertronix and it gave him nothing but trouble right out of the box. If they work good for you? That is nice. Just on a Sunday drive chances are if it craps out the parts have to be ordered. A whole new distributor is what you would need to carry.
Never had a problem but have the points/cond. in the glovebox just in case. Easy to put back in if in a pinch. Waiting for the IgnitorIII Distributor and coil to be available.
[Re: RapidRobert]
#290796
04/22/09 10:53 AM
04/22/09 10:53 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
The stock Mopar EI was/is the most reliable out there. GM burnt caps and rotors, had module issues some years. Ford, Sure, there have been mopar module failures, but that's as esay as carrying a new box- plug it in and go if your grounds are good. How many threads have there been on MSD boxes? They seem to be much more 'touchy' IMHO. I've got one on the race car and haven't had issues but they do seem to be tougher to diagnose.
[Re: RodStRace]
#290797
04/23/09 01:40 AM
04/23/09 01:40 AM
Posts: 3,311 Great White North
Wheeler
Great White North
About 5 years ago, I installed the FBO A688 ignition kit in my 1985 Dodge D150 truck (stock 318 V8 with an Edelbrock Performer intake and Q-Jet carb, Hedman headers and dual exhausts).The truck idled smoother and started a little quicker, but I couldn't tell you if it was faster (I never did a performance comparison). The FBO ignition was reliable and trouble free but I had problems with the Standard RU11 ballast resistor that was supplied with the kit (the ballast resistor burned out twice - the first time it happened, it left me stranded on the freeway ). I installed the stock ballast resistor and the truck was fine. On a side note - the stock black ignition box that was originally on the truck was reliable - never had a problem with it. If I was in the market for a high performance ignition system for my Mopar, I would be taking a hard look at the MSD Ready to Run distributor or a HEI ignition (Davis Unified, Procomp). If you wanted to stick with a conventional Chrysler electronic ignition box, I would go with the FBO ignition box and coil, or a Mopar Performance Chrome Box.
