Re: which elctronic ign mod do you use??
[Re: Azzkikrcuda]
#290782
04/20/09 04:21 PM
04/20/09 04:21 PM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
chrome box w mopar distributor, new plugs that are the correct heat range, starts great.
[Re: mark7171]
#290784
04/20/09 06:32 PM
04/20/09 06:32 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Never had a MSD. Mopar boxes can be swapped cheaply and get you home. I did have a Jacobs ProStreet on my van. That thing made the engine scream!! That was a few years ago and reliability was a big issue. If they were reliable I would get another system. If it failed you could just swap coil wires and go on your merry way. Pertronix? Where do you find extra parts when it quits in BFE? The HEI sounds like where I am going to go with the slant in my Duster.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#290785
04/20/09 07:38 PM
04/20/09 07:38 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Well,.....I've never had a Pertronix fail me yet,......logged 10's of thousands of miles on cross country runs, Hotrod Power Tours, roadraces,etc,etc,etc, year after year........but, you just keep the old points and condensor in the glove box,.....if you ever need'em. easy swap over, or you carry a spare Pertronix Hallcell......But I haven't had the need to, for years now........when I ran points, or MP electronics,.....you always needing a spare set of points, condensor, and a ballast resistor, or if you had MP electronics, you needed a spare ECU, and a ballast resistor,........no ballast with Pertronix, although I do hang one on the firewall, with non-functioning wiring, just for the "original" look,......and if I ever do have a failure, just swap in a spare hallcell, easy as changing a rotor,.....or points and condensor, and replug the ballast into the actual system, a 10 minute job at best......
In the last 30+ years, I've had my share of factory, MP, accell, MSD, etc ignition systems,......a Pertronix done "properly", IMHO outperforms the other systems in reliability, and in many cases performance as well!
[Re: rt66jim]
#290786
04/20/09 09:17 PM
04/20/09 09:17 PM
Posts: 15,304 Omaha Ne
TJP
Omaha Ne
I ran a Wells box purchased at Auzone Zone for years. Car ran 11.08 with it. I bought in to the idea it wasn't good enough. Purchased a FBO box and coil. The car still ran 11.08. If I needed a box a new box I'd go to AZ and save $50. JMO Jim
[Re: mark7171]
#290787
04/20/09 10:00 PM
04/20/09 10:00 PM
Posts: 15,478 the boonies
aarcuda
the boonies
Did away with the harness a while ago. i use the $50 all in one 75 kv E coil/distributor/box procomp vacuum advance distributor.
What a great set up. ground it. contect it with 2 wires it is making fire. Brown and blue with white stripe were the wires i use.
It is awesome. mine came with 12-intial 2o mechanical, 10-15 in the can.
comes with 12 initial???
[Re: DAYCLONA]
#290788
04/21/09 08:30 PM
04/21/09 08:30 PM
Posts: 752 MA
440beeper
MA
Just keep the old points in glovebox...you could always swap it back on the side of the road if necessary.
[Re: 440beeper]
#290789
04/21/09 08:36 PM
04/21/09 08:36 PM
Rug_Trucker
No thanks!
[Re: Rug_Trucker]
#290791
04/21/09 09:11 PM
04/21/09 09:11 PM
Posts: 15,487 Florida
scratchnfotraction
I like the pertronix in a points dist to get a little better advance curve using stock stuff been 9 yrs and no trouble yet,I have the 40,000 kv coil with it as far as finding parts for it...never had to its been 6200rpm bunch of times for me just fixed a 85 dodge van for a old man thats been broke down for a week due to the stock elect crap droped in a points dist and the pertronix is on the way for it the shop has done sucked over 350$ of him and he got 5 miles and a tow home he keeps starting it and go round the block and shut down..start it back up..he is cant believe I hooked it up for him free of charge for him to get going I told him if he keeps on the starter will need to be uped to a mini starter for it points work on a hemi with 2-4 barrels and a 4-speed and turned over some 6000 rpms for yrs whats wrong with simple now days but thats my hickabilly shade tree
[Re: scratchnfotraction]
#290792
04/21/09 09:39 PM
04/21/09 09:39 PM
i run stock boxes i get from a junkyard for 2 bucks. i had a mopar orange and it made no difference at all until it melted. didnt start any different, no more hp, i guess you get more rpms from an orange box but the highest ive ever ran my car was about 5000 just for a second or 2 while revving it.
[Re: Rug_Trucker]
#290795
04/22/09 10:41 AM
04/22/09 10:41 AM
Posts: 271 Dallas, Wisconsin
BurntOrange
Dallas, Wisconsin
A friend had a Pertronix and it gave him nothing but trouble right out of the box. If they work good for you? That is nice. Just on a Sunday drive chances are if it craps out the parts have to be ordered. A whole new distributor is what you would need to carry.
Never had a problem but have the points/cond. in the glovebox just in case. Easy to put back in if in a pinch. Waiting for the IgnitorIII Distributor and coil to be available.
[Re: RapidRobert]
#290796
04/22/09 10:53 AM
04/22/09 10:53 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
The stock Mopar EI was/is the most reliable out there. GM burnt caps and rotors, had module issues some years. Ford, Sure, there have been mopar module failures, but that's as esay as carrying a new box- plug it in and go if your grounds are good. How many threads have there been on MSD boxes? They seem to be much more 'touchy' IMHO. I've got one on the race car and haven't had issues but they do seem to be tougher to diagnose.
[Re: RodStRace]
#290797
04/23/09 01:40 AM
04/23/09 01:40 AM
Posts: 3,316 Great White North
Wheeler
Great White North
About 5 years ago, I installed the FBO A688 ignition kit in my 1985 Dodge D150 truck (stock 318 V8 with an Edelbrock Performer intake and Q-Jet carb, Hedman headers and dual exhausts).The truck idled smoother and started a little quicker, but I couldn't tell you if it was faster (I never did a performance comparison). The FBO ignition was reliable and trouble free but I had problems with the Standard RU11 ballast resistor that was supplied with the kit (the ballast resistor burned out twice - the first time it happened, it left me stranded on the freeway ). I installed the stock ballast resistor and the truck was fine. On a side note - the stock black ignition box that was originally on the truck was reliable - never had a problem with it. If I was in the market for a high performance ignition system for my Mopar, I would be taking a hard look at the MSD Ready to Run distributor or a HEI ignition (Davis Unified, Procomp). If you wanted to stick with a conventional Chrysler electronic ignition box, I would go with the FBO ignition box and coil, or a Mopar Performance Chrome Box.
