Re: oil questions/ zinc......
[Re: 05dakota]
#289090
04/16/09 11:30 PM
04/16/09 11:30 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
so the solution is oil thats $10.75 a qrt?
If you're an oil salesman!
[Re: 05dakota]
#289091
04/16/09 11:42 PM
04/16/09 11:42 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Not exactly. It doesn’t have to be that costly.
That same oil is $8.30 per quart with the Amsoil Preferred Customer membership. Or a less costly alternative could be Synthetic SAE 10W-30/SAE 30 Heavy-Duty Motor Oil (ACD) . The ACD works out to $5.97 per quart Preferred Customer cost.
ACD 10W-30:
Zinc content 1339ppm Phosphorus content 1180ppm
Around the 1200ppm mark for Zinc and Phos., is considered to be adequate for flat-tappets.
Also, consider the cost of a quality alternative motor oil plus the cost of an aftermarket additive. The two added together is getting up there in price. In the end what’s the difference in price, $10-$12? And if you go that rout, you’re not guaranteed 100% compatibility of the motor oil additive package to the aftermarket additive. For example are you going to end up with oil foaming tendencies by using a motor oil and aftermarket additive? That's happened.
One oil product, one cost, no worries… Some like to go that rout, but not all. CompSyn
[Re: Junky]
#289092
04/17/09 10:20 AM
04/17/09 10:20 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Stock or mild builds with flat tappet cams like at least 1200 ppm zinc. Major builds more, due to stronger valve springs etc.
I run 5W40 Shell Rotella T full synthetic which has close to 1400 ppm zinc. Most, if not all, heavy duty (diesel) motor oils have a good amount of zinc. Racing oils too, but may not be suitable for every day cruising. www.bobistheoilguy.com has tons of info.
I read on Bob Is The Oil Guy's web site a used oil analysis stating that the new CJ4 Shell Rotella T (SRT) 5W40 full synthetic at about 1380 ppm zinc. Last night I emailed Shell's tech, who responded back that their newest CJ4 SRT 5W40 has 1200 ppm zinc.
[Re: Junky]
#289093
04/17/09 11:18 AM
04/17/09 11:18 AM
Posts: 3,877 Oregon
hooziewhatsit
Chevron Delo 30wt has ~1200ppm zinc according to their datasheet for it. Here it costs me $13/gallon.
[Re: I go fast]
#289096
04/17/09 01:03 PM
04/17/09 01:03 PM
I totally agree with the comments about buyer beware. Back when all the SM oils came out, I contacted many of the oil mfgs and was told SM was fine for flat tappet engines. Now we now better. Even after the issues came up, when I contacted Amsoil, they wouldn't tell me how much zinc was in their oil, but it was enough. I had two pushrod failures on Amsoil diesel oil back then, change oil to another brand and no more problems. I like to run the motorcycle oils, as they have all the additives you need, without the extra stuff in diesel oils that you don't need. I like this in 5W40 for drivers and our motorhome and in the 20W50 for the TT340 Chally. http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9021703&contentId=7040544
[Re: Mr.Yuck]
#289099
04/17/09 09:32 PM
04/17/09 09:32 PM
CompSyn
Pacific NW USA
Just found a bottle of Lucus additive at Advance for $12. It has zink and some other stuff in it "specially formulated for engines using flat tappet cams" It's a break in lube + additive.
Is it Lucas Oil Stabilizer or another product. Just curious. Below is some information on Lucas Oil Stabilizer.
Click HERE for thread on Lucas Oil Stabilizer.
Click HERE for a look at bench test with Lucas Oil Stabilizer.
[Re: CompSyn]
#289100
04/18/09 01:39 PM
04/18/09 01:39 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
They have two different products. One is an oil stabilizer/smoke reducer similar to 'motor honey'/stp, etc. The other is a zddp additive and motor/cam break-in product. It comes in a 16oz bottle and states that it is not to be used in 1994 or newer cars as it will trash the convertors. I used a bottle to break-in my recent 440 bullet in my sig car and just picked up another for an oil change.
