Page 1 of 3 1 2 3
Windshield Installation Tips #287142
04/13/09 12:22 PM
04/13/09 12:22 PM
Arizona
68CoronetRT Offline OP
Arizona
I am getting read to install the windshield and rear glass on my 68 Coronet. Can anyone offer tips that will help this install go smoothly?
Also, can this be done solo?
Re: Windshield Installation Tips [Re: 68CoronetRT] #287143
04/13/09 12:33 PM
04/13/09 12:33 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think I'm going to have a glass shop install mine.
Did you get the vynal top trim on yet?
Re: Windshield Installation Tips [Re: burdar] #287144
04/13/09 02:20 PM
04/13/09 02:20 PM
Arizona
Arizona
Yes, I got the trim on but it was a chore. Looks good though!
Re: Windshield Installation Tips [Re: 68CoronetRT] #287145
04/13/09 07:55 PM
04/13/09 07:55 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Some one mentioned that they had to verify the clips were correct to hold the trim. There seems to be some differences on repop clips and that they used the thicker rear window rope, 3/8 I believe..
I have the same job coming up soon.. Good luck and post some pics...
Re: Windshield Installation Tips [Re: sthemi] #287146
04/13/09 09:24 PM
04/13/09 09:24 PM
Arizona
Arizona
I ordered my clips from Tom (RT Specialties) so I am not concerned there. Mainly I just want someone that has done this before to suggest a few tips for making the job go smoothly.
I will post some pictures when I actually get into the job. Right now its more like mental prep.
Re: Windshield Installation Tips [Re: 68CoronetRT] #287147
04/14/09 11:11 AM
04/14/09 11:11 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
This is a good post and great timing for me.
I am about to put in my front and rear glass on my 69 road runner. I have the clips in. But I want to make sure I have the right ones in the right place do you have a diagram of the layout of the clips? I will probably pay to have mine put in from the glass company I am buying the new windsheild from. I have done it on other cars but I understand it is kind of a pain.
I would love to see some pictures.
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: Windshield Installation Tips [Re: moepwr] #287148
04/14/09 11:41 AM
04/14/09 11:41 AM
Arizona
Arizona
This is a good post and great timing for me. . . I would love to see some pictures.
I sent you an email with pics.
Re: Windshield Installation Tips [Re: 68CoronetRT] #287149
04/14/09 11:46 AM
04/14/09 11:46 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
Thank you for the email. I will look tonight and make sure I have them in the right places.
Thanks again
Dean
Re: Windshield Installation Tips [Re: 68CoronetRT] #287150
04/14/09 11:55 AM
04/14/09 11:55 AM
greenfield, ind.
P
PLMCRZY Offline
PLMCRZY  Offline
P
greenfield, ind.
i was glass installer for 10 yrs. ten yrs ago most shops around here (ind.) charged 50$ to install your window, that included supplies and we came to you. w/s installers are like alot of trades, they welcome side jobs. dennis
Re: Windshield Installation Tips [Re: moepwr] #287151
04/14/09 01:04 PM
04/14/09 01:04 PM
car48nut Offline
car48nut  Offline
Could you post the diagram of where to put the clips? Front and rear? Thanks
Re: Windshield Installation Tips [Re: car48nut] #287152
04/14/09 01:35 PM
04/14/09 01:35 PM
Arizona
Arizona
These are for a 68 b-body (thanks to Tom at RT Specialties for the posting the pics.)
Front Bottom (10 pcs):
Front Sides (14 pcs):
Rear Window (20 pcs):
Be sure to use the correct screws because heads sticking up too far will cause the molding not to go on.
Re: Windshield Installation Tips [Re: 68CoronetRT] #287153
04/14/09 05:59 PM
04/14/09 05:59 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I'm a vender for R/T specialties parts. Make sure you have the right clips for the 10 that go at the bottom of the front windshield. There are two types of clips that were used in 1968, one for early build date cars and another for later build date cars. I just did this same job on my 1968 Dodge Charger last Friday. My car used the early style clips as pictured above. It took two of us about 15 minutes to install the windshield. We used lots of windex, and a couple of plastic sticks. I swear it took us longer to lock the zipper seal than to install the windshield. I also used a new windshield gasket. Don't forget to use some butyl rubber? ribbon seal at the bottom of the windshield channel before installing the rubber windshield gasket.
Re: Windshield Installation Tips [Re: 68CoronetRT] #287154
04/14/09 06:12 PM
04/14/09 06:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Jim,
I've followed along on Moparts, your Coronet build up,....NICE car!.....Great work,
I'll tell you though, I can machine, fabricate, bodywork paint, and upholester, wiring, engines/transmission, etc, etc, etc,.....But when it comes to front windsheild installs on a 68-70 B body, I'LL GLADLY pay a professional to install it!......if you have your original glass, goodluck, hope it dosen't break ......if you have an installer supply the glass and he breaks it, he replaces it,......your glass, new or old, you might not get someone who wants to install it?.......the B body windsheild gasket is a little trickey to work with, get a guy that's done one before, don't let'em learn on yours
I hope you bought a quality repro, or NOS front gasket?.....during the gasket install you want to apply a bead of window adhesive, be it Butuyl, or Acyr ureathane (NO SILICONES) in each lower corner of the winsheild opening, about 6 inches up the A pillar post, and 12 inches along the bottom corner gasket rail, basically an "L" shape bead of sealer, then install the gasket, these two lower corners need to be sealed, even though your using a gasket, at driving speed, the rain/water is forced into these area by airflow at speed, hence the need to seal these corners, before appling the gasket, no sealer is need in fitting the glass into the gasket, do not use any inside the gasket glass reciever edge......again I strongly recommend a professional install the windsheild, just assist if needed, or point out problems
The rear window is a cake walk, I prefer to use "window tape", a preformed/sized cord of Butuyl rubber,.....generally the B bodies use the 5/16 sized tape, 3/8 dia. I generally find to thick, makes putting the trim on hard, because the window sits to high, and I hate to force the glass and trim down,....1/4" dia is available, but most times is to thin, the glass sits to low,......but every car is different, glass varies somewhat, shape and thickness wise,....so I generally buy all 3 sizes, 1/4", 5/16", 3/8" to have on hand the day I install,....what I don't need, I keep for another project or return,.....nothing sucks more than to start installing glass, and finding onesself driving back to the store for the smaller/bigger size "tape"....and they don't have it!....sound fimiliar? .....
when you install the tape you think you need, install it in a continus line, with the "seam end" on the bottom window channel, in the middle, it's gooey, so you can mould it together, I generally like to put the "tape/cord" right on the inside edge of the window lip, so that no body color shows if the chrome trim dosen't cover it later, do not attempt to fill the entire window channel with tape, 1 continuious peice is all you need, the cord kits usuall come with 2 or more rubber blocks, about 1/4"X 1/4"square or slightly larger, these are to locate the window, use one in each lower corner, they are to keep the glass from sliding down during your install, remove them after your window sets, or trim them off with a razor, flush to glass height, if they get "glued" in.........if you can install the back glass in the sun, on a nice hot day, it helps "settle" the glass down, when you finally drop the glass down, do check glass height and moulding fit, wether you install the mouldings then or later, to confirm you used the "right sized" tape, nothing sucks worse than to have to cut it out and start over later, if you catch it before it sets up, you can just retape with the larger dia, that you should have on hand just incase.......when you put the moulding down, it's best to mask with some tape, any painted areas next to the mouldings edge, so that you don't chip any paint, assistanted by a helper or not, stuff happens.......I'm sure others will chime in, good luck on the Coronet Jim
Re: Windshield Installation Tips [Re: DAYCLONA] #287155
04/14/09 06:51 PM
04/14/09 06:51 PM
Arkansas
hotrod98 Offline
hotrod98  Offline
Arkansas
When I remove windshields from b-bodies, it always looks like there's sealant all of the way across the lower channel of the windshield. I had a local glass shop install the windshield in the 67 hemi GTX and it leaks like a sieve. Also, the inside of the gasket is puckered badly where it lays against the dash panel on the inside. We ordered a better gasket from Chuck's which is supposed to be the premium quality gasket. I was planning to add sealant all of the way across and part of the way up the sides.
As for the sealant for the front...are you talking about the 3M flowable in a tube or the rope style butyl? Looks like 3M is only making one non urethane sealant for windshields now.
I have three winshields to install. The GTX, my Daytona clone and my 68 runner that I just traded for.
1970 Superbird 4-speed, Dana, bucket seats
Re: Windshield Installation Tips [Re: badblack68] #287156
04/14/09 09:25 PM
04/14/09 09:25 PM
Arizona
Arizona
My car had the bottom clips as pictured.
If I read you right you installed the gasket on the window lip and then fit the glass into the gasket?
Re: Windshield Installation Tips [Re: DAYCLONA] #287157
04/14/09 09:31 PM
04/14/09 09:31 PM
Arizona
Arizona
Mike,
Thanks for the detailed post.
Did you use any butyl primer on the glass or window lip?
Also, what size tape did you use on the bottom lip for the windshield?
Appreciate the help,
Re: Windshield Installation Tips [Re: hotrod98] #287158
04/14/09 09:36 PM
04/14/09 09:36 PM
Arizona
Arizona
Wow, three projects and I am struggling with one. There is a 68 GTX down the street from me that has been on blocks for over 10 years. Tried to buy it but they wouldn't even talk to me. Got a peak in the window at the VIN so its not a Hemi car anyway but the mice were tearing up the seats and the sun is drying up everything else.
Re: Windshield Installation Tips [Re: 68CoronetRT] #287159
04/14/09 11:02 PM
04/14/09 11:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Jim,
I don't use any Butuyl primer on the glass, never had a problem getting the glass to adhere and seal to the tape, I only use 3M brand tape/cord
on the front windshield gasket, I use Butuly rubber (3M) when and if I find it, I usually buy the cartrige tube that fits in a cauking gun, if I can't find pure Butuly(getting harder to find in stock), I'll use 3M's arcylic Ureahthane window adhesive in cartrige form, the ureathane sets up fast, so you have to hustle
Re: Windshield Installation Tips [Re: hotrod98] #287160
04/14/09 11:11 PM
04/14/09 11:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Hey Larry,
The repro B body windshield gaskets leave a lot to be desired,......granted it's a difficult piece to manufactuer,........the only ones I've had luck with are the ones from Legendary,.....I'can't recall at the moment the vendor,....but I'm thinking Metro,.....
I know at one time legendary was selling limited supplies of NOS gaskets upon request,......the last NOS one that I purchased from them was about 4 yrs ago.....price wasn't bad, under $200
PS. Larry UPS should be there tommorrow
Re: Windshield Installation Tips [Re: DAYCLONA] #287161
04/15/09 08:23 AM
04/15/09 08:23 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Thanks for the tips you guys, mine is "looming" and this helps.
Is there a particular spacing between the clips at each area i.e.top edge, bottom sides, front winshield, back window,??
Driving modern convenience in classic beauty
Page 1 of 3 1 2 3
