Air compressor oil- can I use motor oil or? #286255
04/12/09 05:01 PM
04/12/09 05:01 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I am out of compressor oil and before I make the hour round trip to get some and waste gas, can I use anything else in there. Motor oil if so, what weight????
thanks
Re: Air compressor oil- can I use motor oil or? [Re: RUMBLON] #286256
04/12/09 05:07 PM
04/12/09 05:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Straight 30wt Non-detergent, it must be Non-detergent...
Re: Air compressor oil- can I use motor oil or? [Re: 1_WILD_RT] #286257
04/12/09 05:22 PM
04/12/09 05:22 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Great thanks
Re: Air compressor oil- can I use motor oil or? [Re: RUMBLON] #286258
04/12/09 05:29 PM
04/12/09 05:29 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
From a guy who used a 5hp 3phz 2 stage Quincy pump with 2 80 gallon tanks for years ... ANY decent oil used on a limited basis can be used.
Straight 30 or 40(depending on temp) is bester. And a detergent oil will not hurt the pump.
Re: Air compressor oil- can I use motor oil or? [Re: RUMBLON] #286259
04/12/09 05:30 PM
04/12/09 05:30 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I've used Mobile One in my compressor for years. No problems. Don't remember the weight. Just whatever I had lying around.
Re: Air compressor oil- can I use motor oil or? [Re: dmerc] #286260
04/12/09 05:41 PM
04/12/09 05:41 PM
Kirkland, Washington
Pacnorthcuda Offline
Napa sells non-detergent oil. Its not that the detergent itself is 'bad', it just serves no purpose in this application, and detergent is not a lubricant.
Re: Air compressor oil- can I use motor oil or? [Re: Pacnorthcuda] #286261
04/12/09 06:27 PM
04/12/09 06:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The way it was explained to me is detergent can cause foaming in an air compressor... In the end any lube has to be better than no lube...
Re: Air compressor oil- can I use motor oil or? [Re: 1_WILD_RT] #286262
04/12/09 06:33 PM
04/12/09 06:33 PM
Never heard of that but maybe... Trying to figure why it might foam in a compressor but not in an ICE?????
And additives that are not lubricants do, in effect, dilute the lubricity of oils. Viscosity improvers are a major one--thats why straight weight oils are such good lubricants if the application doesn't benifit from a multi.
