Re: 0A163690
[Re: 6bblgt]
#2446749
02/05/18 11:53 AM
02/05/18 11:53 AM
Posts: 4,279 Florida
blewbyu
F 440 11-12 OA163690 CAST 10 29 68 from one of the following Plymouth B-bodies: RM21V0A RM23V0A RS23U0A RS23V0A WOW!! That's an early casting date for a 70 car I would think?
Found 340 block #450217 Dated 1970
[Re: Alaskan_TA]
#2449583
02/10/18 04:15 PM
02/10/18 04:15 PM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
If this is yours, it's your lucky day. pm me here
Still looking for LM29H1B415501, '71 Demon 340
Re: Found 1970 Hemi Block #0B194914
[Re: Dartman440]
#2453757
02/19/18 02:06 AM
02/19/18 02:06 AM
Posts: 17,514 Las Vegas, NV
6bblgt
Las Vegas, NV
I believe this came out of a 70 Hemi Cuda' but I could be wrong. This block is good but has been heavily machined and prepped for racing. Casting date is early 9/30/68. Cast# 2468330-1. it is an "in-violet" automatic hemi'cuda - white top & interior - in Sweden last I heard what's the "MN" number?
Found 1970 Hemi Block 0B 194914 BS23R0B194914
[Re: 6bblgt]
#2453815
02/19/18 10:22 AM
02/19/18 10:22 AM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I believe this came out of a 70 Hemi Cuda' but I could be wrong. This block is good but has been heavily machined and prepped for racing. Casting date is early 9/30/68. Cast# 2468330-1. Dean, it went to Sweden in 1976, but on June 10th 2005, it was for sale via Ebay in Illinois. I have an email address for the seller at the time, if you email me, I will forward it to you.
[Re: 6bblgt]
#2454866
02/21/18 12:09 AM
02/21/18 12:09 AM
Posts: 1,411 Southern Michigan
Dartman440
Southern Michigan
Thanks Barry, I know the car now. It came to Michigan as a project. It was gone thru in Michigan and sold to Arkansas, Then Iowa. Don't know the rest. All numbers on bottom of block. 4262805 31444. It has a Maltese cross, an large A+ E
[Re: Dartman440]
#2462473
03/07/18 11:10 AM
03/07/18 11:10 AM
Posts: 43,512 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Found 69 440 RS23L9G137767 it is about to go with a car that is sold but thought I would post it here first. Also found a 69 340 LS23P9E111594 from a GTS built in LA.
JB Rhinehart, Realist
A-Body's RULE!
Re: Found 2B113156 4-speed
[Re: Rhinodart]
#2466802
03/15/18 09:48 AM
03/15/18 09:48 AM
Posts: 339 western PA
stevet340
western PA
I have a 1972 A-body 4-speed vin 2B113156. If it is yours message me. Thanks Moparts.
Re: Engine and Trans Lost & Found
[Re: RonLiv]
#2474450
03/30/18 04:35 PM
03/30/18 04:35 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Looking for 383 vin 300867 You should specify model year & assembly plant.
build sheet needed for sublime 70 gtx
[Re: FC7cuda]
#2503915
06/03/18 02:17 PM
06/03/18 02:17 PM
Posts: 1,794 BC Canada
ogopogo
BC Canada
looking for buildsheet for 70 gtx last seen in calgary area 0G201891 ogopogo69"at"shaw.ca
Re: 18 spline 4 speed 1970 0A124482
[Re: Alaskan_TA]
#2506016
06/08/18 07:30 PM
06/08/18 07:30 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
found 73 340 motor almost compete vin 3B3 1619 I will be offer it for sale once I take some pictures
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: Alaskan_TA]
#2506051
06/08/18 09:15 PM
06/08/18 09:15 PM
davesmopars
cheshire, ct
You are missing a VIN digit? yes not stamped between the 3 and the 1
