what backspacing came with 8x15" steelies? #281367
04/08/09 12:01 PM
04/08/09 12:01 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
I have 7x15's now and was wondering what the backspacing is on the 8" rims.
is there more than one type?
thanks.
Re: what backspacing came with 8x15" steelies? [Re: west] #281368
04/08/09 12:07 PM
04/08/09 12:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
thanks.
4 1/2" for 15x8 mopar steelies (ramcharger/super coupe)
4 1/4 for 15x7 mopar steelies, rallyes....
Re: what backspacing came with 8x15" steelies? [Re: autoxcuda] #281369
04/08/09 12:20 PM
04/08/09 12:20 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
darn,i was hoping for more backspacing.
don't suppose mopar had some 9" rims that will fit under my dart huh?
my next option is to have some custom made
Re: what backspacing came with 8x15" steelies? [Re: west] #281370
04/08/09 02:58 PM
04/08/09 02:58 PM
scratchnfotraction Offline
you will be pushing it with 8s on the Dart
may need the lip rolled or a massage to the inner wheel well...cut it back to the frame rail or mini tubb it
what rear axle you got?
my 68 dart needed 7" with 4 1/4 bs with the 74 7 1/4-4.5 wbp axle,could not get closer to the spring,had 1/8" clearance
needed 4 1/2" bs with 7" rims on the A-body 8 3/4 axle with moser axles and greens with the large B-body brakes,same thing here 1/8" clearance at the spring and tire bulge
it was centered in the wheel well good but could not get a wide rim or tire with out work on the lip and inside of the tire well
runing 12" rims with 4 1/2" bs now with 29x15.5x15 M/Ts on the A-body 8 3/4 and got a 1/8" clearance at the tire bulge and spring
not saying it cant be done and may vary car to car
its just what I got with mine
I think 4 1/2 bs is gonna be the ticket with what ever rim you run on the A-body with out moving the springs
good luck
Re: what backspacing came with 8x15" steelies? [Re: scratchnfotraction] #281371
04/08/09 03:06 PM
04/08/09 03:06 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
springs are moved,there is room for a biiger rim i just need more backspacing cuz im at the lip if the wheel well as you said.
what about magnum 500's can i get those anywhere with custom b-spacing?
Re: what backspacing came with 8x15" steelies? [Re: west] #281372
04/08/09 03:58 PM
04/08/09 03:58 PM
I have only had 14" mag 500 rims and the were 7" with 4 1/4 bs IIRC
if your spring is moved you should be able to use 5"-5.5" bs with an 8" rim maybe even get a 10" in there
just remember tire bulge and have clearance for it
Re: what backspacing came with 8x15" steelies? [Re: west] #281373
04/08/09 04:02 PM
04/08/09 04:02 PM
Scottsdale, AZ
K
kenz Offline
kenz  Offline
K
Scottsdale, AZ
Yes!! Summit can order them. I'm getting a pair of 15 x 7's with 4 1/2 back spacing. It's only $20 extra per wheel and they said it'll take a couple of weeks.
Thanks,
Ken
Mopars Unlimited of Arizona
www.moparsaz.com
Re: what backspacing came with 8x15" steelies? [Re: kenz] #281374
04/08/09 04:22 PM
04/08/09 04:22 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
Thanks,
Ken
thanks ken,thats good news more cash than $40 steelies but I may go that route.
wondering what backspacing your rims come with normally?can't be much diiferent than what you ordered cuz i think i'll try to keep the same size rim up front as my 15x7 steelies.
Re: what backspacing came with 8x15" steelies? [Re: west] #281375
04/09/09 03:17 PM
04/09/09 03:17 PM
Scottsdale, AZ
K
kenz Offline
kenz  Offline
K
Scottsdale, AZ
The 15 x 7's normally come with 4 1/4" back spacing. I'm trying to keep the tires in as far as possible. I could actually go with 4 3/4 back spacing if I wanted to get real close (1/8") from the upper BJ. :-)
Good luck.
Ken
www.moparsaz.com
Re: what backspacing came with 8x15" steelies? [Re: autoxcuda] #281376
04/12/09 11:58 AM
04/12/09 11:58 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Every factory 15 x 8 steel or coupe wheel that I have come across have a 4 1/4 backspace.
Re: what backspacing came with 8x15" steelies? [Re: duster2] #281377
04/12/09 01:14 PM
04/12/09 01:14 PM
petaluma,ca. u.s.a.
west Offline OP
west  Offline OP
petaluma,ca. u.s.a.
autoxcuda says 8" steelies are 4 1/2" backspacing.
who's right?
