Strange squeaking noise #281023
04/07/09 10:03 PM
04/07/09 10:03 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
I have a very slight squeak that has suddenly appeared. Seems a little louder when you first fire the motor and slowly goes away. Appears to be in the valvetrain as I cant hear it under the car or in the front of the motor. Took one side of the rocker assembly off and everything appears OK.
Any ideas or tips to find it?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Strange squeaking noise [Re: Von] #281024
04/07/09 10:07 PM
04/07/09 10:07 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Do you have roller lifters??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Strange squeaking noise [Re: Von] #281025
04/07/09 10:39 PM
04/07/09 10:39 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Is the nose or tail of the rocker rubbing the insides of valve cover? I have had to machine reliefs in the VC's bofore to clear the rockers on aftermarket heads.
8.30's @3400 lbs
Re: Strange squeaking noise [Re: hemi-itis] #281026
04/07/09 10:39 PM
04/07/09 10:39 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
No. Not in this motor, not yet anway.
Re: Strange squeaking noise [Re: Mike Swann] #281027
04/07/09 10:41 PM
04/07/09 10:41 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Possibly..There are 2 marks on the inside of the VC. I'll clay em and see if they are rubbing.
EDIT. Checked em and they arent rubbing....
Re: Strange squeaking noise [Re: Von] #281028
04/07/09 10:56 PM
04/07/09 10:56 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Alternator belt?
Re: Strange squeaking noise [Re: ProSport] #281029
04/07/09 11:02 PM
04/07/09 11:02 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Hmmmm, pushrods maybe??
Kidding, saw your other thread.
