Strange squeaking noise
#281023
04/07/09 10:03 PM
04/07/09 10:03 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I have a very slight squeak that has suddenly appeared. Seems a little louder when you first fire the motor and slowly goes away. Appears to be in the valvetrain as I cant hear it under the car or in the front of the motor. Took one side of the rocker assembly off and everything appears OK.
Any ideas or tips to find it?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Strange squeaking noise
[Re: Von]
#281025
04/07/09 10:39 PM
04/07/09 10:39 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Is the nose or tail of the rocker rubbing the insides of valve cover? I have had to machine reliefs in the VC's bofore to clear the rockers on aftermarket heads.
8.30's @3400 lbs
[Re: hemi-itis]
#281026
04/07/09 10:39 PM
04/07/09 10:39 PM
Von
NE Oklahoma
Do you have roller lifters??
No. Not in this motor, not yet anway.
[Re: Mike Swann]
#281027
04/07/09 10:41 PM
04/07/09 10:41 PM
Von
NE Oklahoma
Possibly..There are 2 marks on the inside of the VC. I'll clay em and see if they are rubbing.
EDIT. Checked em and they arent rubbing....
