Wiring harness for Sun tach? #279877
04/06/09 08:22 PM
04/06/09 08:22 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Someone gave me an old Sun Super Tach II that was working fine when pulled. Sadly, the original owner lost the original wiring harness (4 wires) and nicely soldered four wires to the posts at the back. Even more sadly, all the wires he used are red!! So I have no idea what goes to where. I can see some small letters near the posts that look like G, I, L, and maybe B. Does anyone know what they mean? Thanks!
Re: Wiring harness for Sun tach? [Re: polkat] #279878
04/06/09 08:25 PM
04/06/09 08:25 PM
car48nut Offline
car48nut  Offline
could be G= ground, I= ignition,B= battery L=light
Re: Wiring harness for Sun tach? [Re: car48nut] #279879
04/06/09 09:28 PM
04/06/09 09:28 PM
Sterling Conn
manymopars Offline
manymopars  Offline
Sterling Conn
I happen to have an original installation and instruction sheet for the Sun super Tach II.There should be a T,L,G and B terminal,the T connects to the negative side of the coil,the G goes to engine ground,L goes to dash light circuit,and the B terminal goes to ignition switch or accessory terminal of fuse box.Hope this helps.
Re: Wiring harness for Sun tach? [Re: polkat] #279880
04/06/09 10:39 PM
04/06/09 10:39 PM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: Wiring harness for Sun tach? [Re: wildman340] #279881
04/07/09 01:30 PM
04/07/09 01:30 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Thanks everyone. That's what I needed!
