Re: Please, Help me pick a cam
[Re: 1fastrunner]
#274430
04/01/09 09:54 PM
04/01/09 09:54 PM
Posts: 1,401 northeast ohio
hulmule
northeast ohio
what are you going to do with the car?? if it's a driver you'll be un happy with the 509. i had it in my R/R with a4 sp and 391 didnt come alive till 1800- 2000. idle was huh ruff. my fiend runs the 484 and everyone i talked to drop down to the 484 and was happier. or go to a comp or a reed cam
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: hulmule]
#274431
04/01/09 10:18 PM
04/01/09 10:18 PM
Posts: 777 Washougal,Wa
Dodge
Washougal,Wa
I had a 509 in my 70 Cuda with a 440. It must not of had enough compression. It was a real dog. I put a Comp Cam XE274H and it was like night and day. Very happy. It pulls hard from the bottom rpms to top.
Stand behind your word
[Re: DaytonaTurbo]
#274433
04/01/09 10:55 PM
04/01/09 10:55 PM
Posts: 5,159 CT
GTX MATT
CT
The 509 has for a long time been the mainstay of the MoPar big block performance machine. That being said its outdated, I'd run something from Hughes or Engle.
[Re: GTX MATT]
#274434
04/02/09 12:03 AM
04/02/09 12:03 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
It will realy depend on what you want in the car. Will it be a street/strip car or street only ?? The MP .509 will make great power for what it is in the right combo. But it has a nice lopey idle that is great if you like that and can live with it. And you need to run a good bit of gear and converter with the .509 along with at least 10.0 comp imo. In the right combo the .509 will scream but if your car is street only and you dont set the combo right to get low end with the .509 you wont like it. Street only as a driver and a nice idle then I would go with as stated the Comp ' Lunati , Hughes , Engle or Crane. Call the cam company and tell them the combo you are building so they can help you or get in touch with Dwayne Porter as he is very good with cams. Good luck , Ron
[Re: 383man]
#274435
04/02/09 12:29 AM
04/02/09 12:29 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
Call one of the Mopar engine shops, they will help you out.
We really do have some great Mopar shops around the country so it is hard to point you to just one.
I want my fair share
[Re: 1fastrunner]
#274440
04/02/09 08:21 AM
04/02/09 08:21 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
My car is a '71 Roadrunner w/ a 4-speed and 3.23 gears. It will be street driven. Thanks, Jim
509 is a good cam for a 10:1+ motor, good heads, intake, headers and 3.91's or better. If you want to keep the 3.23's you'd probably be better off w/ a different cam. Something a little more low-ended.
[Re: 1fastrunner]
#274443
04/02/09 01:04 PM
04/02/09 01:04 PM
383man
Balt. Md
Definetly do not want to use the .509 cam in that combo. The MP stock bigblock cam would work nice in that. It has about .455 lift and .258 advertised I believe. Or just call Comp or Crane or whatever cam you decide on and let them help you. Ron
[Re: 451Mopar]
#274444
04/02/09 02:17 PM
04/02/09 02:17 PM
Posts: 2,124 Hunt Valley, Maryland
1fastrunner
It's a 440 30 over w/ Arias piatond (about 9.5), but that could change if the heads are planed. I want to maintain pump gas, it has a Holley 750 dp, and an Edelbrock chp4(?). Hooker super comps 1 78/" and a 2.5 exhaust, which will be upgraded to 3" in the future. I'd like to keep the 3.23 gears as I like to drive distances. The motor is being rebuilt. I'm looking for the best cam for this set-up including the stealth heads. Thanks, Jim
[Re: 1fastrunner]
#274445
04/02/09 02:29 PM
04/02/09 02:29 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
I'm planning on using either the 509 cam or something very similar. Is MP the way to go, or should i be looking at other vendors? Jim
When you ask everyone with different opinions,this is what you get.
[Re: DaytonaTurbo]
#274446
04/02/09 08:55 PM
04/02/09 08:55 PM
Posts: 7,664 IN
ahy
IN
If you want a good street/strip cam and have around 10:1 compression I would definitely with either the Comp XE275HL or the Lunati Voodoo 60303 which is a few degrees milder than the aforementioned comp grind.
With a manual trans street driven its loads of fun to have lots of torque on tap from 2000 to 5000 RPM. The 509 won't give you that - it has too much duration plus you can't run a loose convertor to compensate. A faster rate cam as posted above with enough lift to take advantage of your heads would work much better.
With the stealth heads, if you can get your piston to zero deck so the "quench" equals the .040 (approximate) thickness of the head gasket you can run more compression than 9.5. 10.25 would still be conservative and give more torque and power. If your piston is "down in the hole" then 9.5 or a little more is probably about right.
[Re: Airgrabber]
#274447
04/02/09 09:07 PM
04/02/09 09:07 PM
Mr.Yuck
Brookeville, Md
The 484 works well with your combo. Nice low end torque and power across the board.
mopar 484? that will be a dog w/ 3.23's it's not much different than the 509. It pulls terrible vacuum and has poor street manners. The old grind anyway.
[Re: Mr.Yuck]
#274448
04/02/09 09:44 PM
04/02/09 09:44 PM
Posts: 1,261 ILL
mark7171
ILL
the 484 is gonna want gear. It is a racing cam.
not as bad as the 509. Which is a serious cam that is every bit as good as the cams today. Most modern cams are small base circle. If a thumping shaft is getting shoved in a mill hole, It better be thick and bumpy.
[Re: Dodge]
#274449
04/02/09 09:59 PM
04/02/09 09:59 PM
1fastrunner
So is this a good choice? Jim
[Re: mark7171]
#274452
04/02/09 11:05 PM
04/02/09 11:05 PM
Posts: 4,179 California
mickm
California
that's what my wife says, but i don't pay attention to her...
[Re: mickm]
#274453
04/02/09 11:18 PM
04/02/09 11:18 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
XE268 or similar. It works very well from idle up. I think any smaller and you're leaving power on the table for no reason. But I also think the 274 is too much for it.
[Re: Brian Hafliger]
#274456
04/04/09 10:58 AM
04/04/09 10:58 AM
1fastrunner
That rpm range seems a little high for me. As far as the stealth heads, I'm not porting at this time, maybe milling them to get to 10 compression. I have a 4-speed with 3.23 gears, and my rpm range is probably above 1000-3000 for most of my street driving. Some of the Comp cams I'm looking at are: 256H, 260H, XE262H, 265DEH, 268H, & 275DEH. I'm not eliminating any other brands or grinds, but these are just from looking at their site. Jim
[Re: 1fastrunner]
#274457
04/04/09 11:33 AM
04/04/09 11:33 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I run the XE262H in my 383, which is slightly "bigger" than the stock magnum cam. It performs very well for the street. With 275/60/15 on the rear, a 727 and 3.73 gears I can blow the tires off from an idle, from a stop. So, I'd think the XE268H would work about the same in a 440 as the XE262H in my 383... The 262 gives my 383 a nice noticeable muscle car idle.
The XE274H cam may work good for you too if your compression is at least a true 9 to 1.
[Re: Junky]
#274458
04/04/09 01:24 PM
04/04/09 01:24 PM
Dont overlook the Lunati Voodoo cams. Cam's have come a long way in 40 years. And the 509 is a great cam still. But its not a nice street cam!The .475/.494 would be a great choice for your combo. It's low duration. Keeps the pressure and vacuum up. It doesnt need alot of gear either. I have it in my 72 New Yorker with 373's and i'll tell ya. It aint your grandpa's New Yorker! Great street cam!!!!
#274459
04/04/09 10:27 PM
04/04/09 10:27 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd look at the voodoo 60303, 60304, or comp XE275HL
[Re: 1fastrunner]
#274460
04/05/09 01:37 AM
04/05/09 01:37 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The Lunati 60303LK 226/234 @ 0.050, 0.494"/0.513" lift, 110 LSA would be a good pick, and it is one of the least expensive cam/Lifter kits at $180. If you are going for more power, the Comp XE275HL cam is really nice, 231/237 @ 0.050", 0.525"/0.525", 110 lsa, and the cam/lifter kit is only $210 from summit racing. The Hughes HEH2832BL3 cam (228/232 @ 0.050", 0.524"/0.540" lift 110 lsa) should give you the torque of the milider Lunati cam and near the HP of the Comp cam, but it is the most expensive at about $270 for cam and lifters. Anyhow thats my
