Did i wreck this new fuel line? I am mad. #272639
03/31/09 05:49 PM
03/31/09 05:49 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I bought these from the Right stuff and they came today. So off with the old 5/16th line and on with the new 3/8 line. However I almost had it in the hole that leads to the front after messing with it for 45 minutes and I got this bend in the difficult area that wraps the corner?????
Is it junk? any way to get the pinch out of it. I went so darn slow and tried so hard, but these are a pain in the tila?
Re: Did i wreck this new brake line? I am mad. [Re: RUMBLON] #272640
03/31/09 05:52 PM
03/31/09 05:52 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I would take a SWAG and say that it is pretty much FUBAR at this point.
Re: Did i wreck this new brake line? I am mad. [Re: RUMBLON] #272641
03/31/09 05:53 PM
03/31/09 05:53 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Yup, it's pooched. That kink is no good, unless you are able to cut it, flare the new ends left when you removed that piece and can find a high pressure fitting you're looking at getting another length of tubing.
Bummer dude
Re: Did i wreck this new brake line? I am mad. [Re: RUMBLON] #272642
03/31/09 05:54 PM
03/31/09 05:54 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
another
Re: Did i wreck this new brake line? I am mad. [Re: RUMBLON] #272643
03/31/09 05:55 PM
03/31/09 05:55 PM
moparmandc Offline
moparmandc  Offline
ouch! looks like scrap to me. where it is at it don't look like you can splice it very easy either.
Re: Did i wreck this new brake line? I am mad. [Re: RUMBLON] #272644
03/31/09 05:58 PM
03/31/09 05:58 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I'm gonna assume you meant fuel line
yup, its junk. I would cut out the kink and replace it with a short piece of high quality fuel line and a couple ss clamps.
Or replace the entire line, your choice
Re: Did i wreck this new brake line? I am mad. [Re: nomore65BelvJim] #272645
03/31/09 06:01 PM
03/31/09 06:01 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
And buy at least a medium priced tubing bender or find some of the coil spring sleeve material to wrap around the line before you repeat the 'process'.
Re: Did i wreck this new brake line? I am mad. [Re: nomore65BelvJim] #272646
03/31/09 06:01 PM
03/31/09 06:01 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Yep, I bought the fuel and brake lines all for the same car.
I dont know how I could have been any easier on this thing. And it still is not that close to fitting correctly. and more
Re: Did i wreck this new brake line? I am mad. [Re: Classof70Chally] #272647
03/31/09 06:03 PM
03/31/09 06:03 PM
Re: Did i wreck this new brake line? I am mad. [Re: nomore65BelvJim] #272648
03/31/09 06:08 PM
03/31/09 06:08 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I will buy a tubing bender. I didnt know I was going to need one, as I though this would be a lot closer to the original, thus eleminating the need. Oh well, another $75.00 down the drain. Its only money, right. what kind of tubing bender do you guys reccomend and Are the stainless lines any better????? If I get another, maybe fine lines will be a closer match??
DAVE
Re: Did i wreck this new brake line? I am mad. [Re: RUMBLON] #272649
03/31/09 06:18 PM
03/31/09 06:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've used Fine Lines dozens of times without any issues...
Re: Did i wreck this new brake line? I am mad. [Re: 1_WILD_RT] #272650
03/31/09 06:25 PM
03/31/09 06:25 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Tubing bender, like th eone I just pulled out of my shop tool box, that I have never used, or maybe I did on a day when I was actually thinking about what I was doing.
This seem cumbersome, do they make a better one? whats best, maybe I should just buy stock and flaring tools and make my own if I am going to have to mess with them after buying them?
Re: Did i wreck this new brake line? I am mad. [Re: 1_WILD_RT] #272651
03/31/09 06:27 PM
03/31/09 06:27 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Just cut and splice. No big deal.
Re: Did i wreck this new brake line? I am mad. [Re: earlybee] #272652
03/31/09 07:00 PM
03/31/09 07:00 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
just get another peice about 2feet long carfully make your bend then cut it down till it lines up with the staight part and splice,unless its a looks thing that will work.
Re: Did i wreck this new brake line? I am mad. [Re: RUMBLON] #272653
03/31/09 07:08 PM
03/31/09 07:08 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
A coil spring bender is cheap (<$5.00), easy to get on and off, and supports the tubing while you bend it. I bought one from the Plumbing Dept. at Ace hardware.
Re: Did i wreck this new fuel line? I am mad. [Re: RUMBLON] #272654
03/31/09 07:21 PM
03/31/09 07:21 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
3/8 line is not easy to bend into a 90, even with a tube bender, i tried 2 benders, one as show on this page and another one, they both kinked the line, i decided to run braided line instead, good luck
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Did i wreck this new fuel line? I am mad. [Re: RUMBLON] #272655
03/31/09 07:34 PM
03/31/09 07:34 PM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
I would cut the bad section out. Then replace with a union or elbow. they make compression fittings that should work, found at the local hardware.
I also bought some anodized AN type with 3/8" compression from Summit a while back. They worked fine and are also available in a sweeping elbow, this will not restrict the flow.
Ed
Re: Did i wreck this new fuel line? I am mad. [Re: deansrr] #272656
03/31/09 07:39 PM
03/31/09 07:39 PM
SK, Canada
E
etek Offline
etek  Offline
E
SK, Canada
I've heated line before for 90's - works much better.
Re: Did i wreck this new fuel line? I am mad. [Re: etek] #272657
03/31/09 07:56 PM
03/31/09 07:56 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
FYI stainless looks great and last forever but is harder to bend than the mild steel.
Re: Did i wreck this new fuel line? I am mad. [Re: etek] #272658
03/31/09 07:59 PM
03/31/09 07:59 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I just bent my fuel line yesterday (5/16"). To make a 90, I used a spool-type bender ($10 at the local NAPA) and bent it about 60*, then moved toward the apex of the bend a little, bent another 5* and did that a couple more times, working away from my original bend, till I finally got a 90* bend. Granted, the radius of that bend is larger, but it doesn't have any kinks.
